FRONT ENGINE PLATE
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: FRONT ENGINE PLATE
    Posted: 07 Mar 2025 at 6:58pm
LOOKING FOR A FRONT ENGINE MOUNTING PLATE FROM A D-21, 210 , OR 220
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2025 at 9:31am
just an fyi, the D21 is it's own animal, the 210/220 are the same as each other and frame mounts are wider than the D21.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2025 at 12:11pm
I WANT TO PUT AN L2 ENGINE IN A BOAT AND I NEED THE HYD PUMP MOUNTING BRACKET HOLE TO HAVE HYD. FOR STEERING. I'LL HAVE TO MODIFY THE MOUNTING ANY WAY SO THE WIDTH DOESEN'T MATTER
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 9:41am
I looked up the number for them on agco parts books, then searched ebay and found rock valley tractor parts had what I needed a few years ago when I needed another for a 210. That's where I'd look.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 11:55am
Any 426 industrial engine has the removable plate to install the hydraulic pump.
Have one in my one 220
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 7:03pm
I have one, Farley iowa
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 4:09pm
HELLO
WHAT KINDA MONEY YOU'D NEED TO GET FOR IT?
  I HAVE A LAWN MOWER REPAIR SHOP AND I'M AUTHORIZED DEALER FOR ALL THE MAJOR SMALL ENGINES MAYBE WE COULD DO SOME HORSE TRADING IF YOU'D BE INTRESTED
This page was generated in 0.176 seconds.
