Little bit of snow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Little bit of snow
    Posted: 05 Mar 2025 at 6:40pm
Plowed the church lot this AM - well started then - Takes from 1 hour with a lite snow to 2 hours with a moderate snow .
  Today 4 hours of moving 11 inches of snow with heavy wet base .
Could make one pass and roll snow over , then had to plow it with blade straight as could not roll it a second time .
 Had to cut lot into small pieces and plow those off one direction then come back and clean up spilled snow off blade .
 Normally plow in one direction and stack at end of lot , today 2 sides of lot have 4 to 6 ft high banked snow I pushed up .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2025 at 7:12pm
DANG... we got 1/8 inch... and it was gone in an hour !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2025 at 8:57pm
good news is only 15 days until SPRING !!!
bad news, have to set clock AHEAD this weekend...I have 6 to do, no 7 ,forgot about truck...
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2025 at 1:50am
We got about 9" of snow and ground wasn't frozen but wet and soft.  Made a trail with Bobcat from barn to house and then to road and moved the bank of snow the township truck made at end of driveway.  Then moved more snow to park the car out near the road.
The joys of spring type weather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2025 at 3:28am
Blowing and Snow/Rain mix for a few hours then done, 30 minutes away and nothing where ours accumulated about an inch but was plastered on walls and machines facing the wind. That howled at around 30mph until well after midnite and has currently subsided to a breeze. Got little nothing accomplished yesterday, made tuna salad for dinner as is Ash Wednesday start of Lent, will be a Friday Fish Head a few weeks.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2025 at 8:15am
Ours was lots of wind 35-45 plus gusts, rain dropping temp so changed to snow after dark Tuesday, Wed am still lots of wind, gusts recorded @ 55 - 60mph. Drift by garage a bit higher than the snowblower, Cleaned snow off, 1/2" ice underneath. Sun came out Wed about noon, by dark ice gone where not covered by snow or in shade.
