leaking injector 6080
rowtooe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowtooe Quote  Post ReplyReply Direct Link To This Post Topic: leaking injector 6080
    Posted: 09 Nov 2010 at 8:08am
I have fuel leaking out where the injector mounts to the intake manifold. is there a rubber seal that can be replaced? Does anyone know what the problem could be?
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 9:59am
Yup, sounds like a sealing washer, I think you can get at your Agco dealer or injection shop, Good luck.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 10:02am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 11:16am
somethings wrong here in terminology, the injector does not go in the intake manifold, injectors are held via bolts and hold down in a cummins type copper sleeve pressed into and sealed in the head.  Fuel injectors will not leak fuel out side the engine unless broken or split due to water in fuel. Leaks occur from drip lines seeping and running into the hole the injector sets in then when engine gets hot it comes out and appears to be coming from the injector. The most common thing we find is the valve cover is leaking and allow oil to get in injector hole and them comes out the outside thus looking like fuel leak .  A leak in an injector will also be noticable as a miss in the engine and a massive leak.  Fuel at 3000 psi + will not 'seep' and cannot be stoped by seals except from the drip lines.  Also keep in mind on 6080's and all 4.33 engines there are no sealing washers on the bottom of the tip as there are in 2200 solid non - tube  heads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 12:20pm
I have seen several times where someone "rebuilds" the bosch bar stock injectors, and doesn't lap the mated surfaces, and this causes a seeping type of leak between the parts inside the injector. No seals are used though. Dust seals are not for sealing fuel. Hopefully this will help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowtooe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 1:24pm
I don't understand a drip line, is this a special line and if so what is it's purpose? How do I corredt the drip?
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 1:28pm
Sorry, Tim and ED, I myself read the guys ? wrong - black out what I said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 2:33pm
return line bolts to the side, and goes along from one injector to the next. The hollow bolt is fragile, and the 2 copper washers are prone to leaking. Don't overtighten the banjo bolt, you will break it off. good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowtooe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 2:40pm
Thanks I will check the return lines first, that sounds like the easiest, You guys are great there are a lot of smart people out there.. I am just a toolmaker who does haying in the summer, I picked up this 6080 for 1000 bucks , but it has a few problems. Thanks for the info, you will be hearing more from me.
This page was generated in 0.110 seconds.
