Model FPD 50-24-2PS Forklift
sinklar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sinklar Quote  Post ReplyReply Direct Link To This Post Topic: Model FPD 50-24-2PS Forklift
    Posted: 09 Nov 2010 at 7:40am
Just purchased a Allis Chalmers Forklift Model FPD 50-24-2PS, Serial 17209581. Specifications Pounds 4200, Center 24' Lift 168". Does anyone know the year model? Where is a good place to get a service manual for the lift. Also where is the best place to buy seals for the lift cylinders? It pulls good in reverse but slips when going forward up a 20 degree or so incline.
towmotor tim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote towmotor tim Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 1:53pm
F=forklift P=Pneumatic D=diesel 50=5000 lb capacity 24=@24 inch load center 2ps=speed power shift trans. That machine is a 1960. That has the 2 spd power shift trans. Down shift it on an incline!
The packings are standard not metric so any hydraulic shop will have them. Old AC dealers can get them with a mast number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sinklar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 9:38pm
Thanks for the reply. I bought it used and it had a 4 cylinder gas engine in it. Also I figured out the lack of power problem the inching valve was not closing all the way. Adjusting the linkage corrected the problem and it will spin the tires now. It does have the 2 speed transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 6:55am
Gas engine ??? Mine has a diesel in it,a Buda ??.Same model number. Can lift 5,000# up 7 feet ! Always in low gear,scary going down the road at any speed !Besut $$ I've spent in a long time and it is an Allis !
Nice to know someone else has one
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2020 at 9:17am
OK, hoping to reopen this thread..
I'd like to know how to put the '2 speed' control BACK onto the dash or wherever it's supposed to be.
Mine has a 'custom' lever on the floorboard, leftside, behind the heel of my boot.
Up seems to be low, down = high.
A picture would be nice....Google hasn't been to helpful, sigh....
Post Options Post Options   Thanks (0) Thanks(0)   Quote sinklar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2020 at 9:46am
I don't think mine has the 2 speed option. I will try to find my manual over the next couple of days and see if it has a drawing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2020 at 5:25am
Thanks.. I've asked Google, several ways, but can't find a picture, cept one that kinda shows a knob on stick,near the parking brake, left of the 'inching' pedal.
I may create another 'winter project' and try to figure out how to make it. Right now my left heel hits the 'lever' down and into high gear.
meantime I might just put into low and disconnect , under the footboard access panel.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote sinklar Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 10:21am
Here is a picture from my forklift, it show the cable by the steering wheel. Also I have a picture from the parts manual I have included. If you by chance find a suitable cable I would be interested because mine is froze up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sinklar Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 10:27am
The other picture
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 11:29am
you can have a cable made
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2020 at 2:04pm
hmmm... your hi-lo cable is where my parking brake is attached ! Makes sense about a cable instead of 'bars of steel'....
as a 'bodge', I've disconnected the PO bodge, stuck it in LO and real happy I can get up my driveway now  without taking a friggin run from acorr the road !!!
I should make it a real 'Winter project' though....
Thanks
Jay
Dan W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan W Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2020 at 10:10pm
I have a FP50-24 2ps. Serial 65839. It has a lot of play up and down on the output shaft of the transmission. What transmission is this? Is there parts break down available?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2020 at 5:24am
Hay Dan I don't know but does yours have a hi-nu-lo range gear shift ? You can save pictures and post them, or even email me them( greensvillejay@gmail.com).
I KNOW the Ujoint 'drivehaft' is missing LOTS of needle bearings.....
I've yet to find a manual for mine. It has a Buda 4cyl  BD153 diesel in it.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan W Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2020 at 5:01pm
Yes it needs a ujoint but before I open a can of worms I want to have an idea of what I am getting into. The output shaft is definitely moving up and down in the trans. I found a lever on the side of trans I am pretty sure it is for the 2 speed selector I will take pics tomorrow .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2020 at 5:14pm
I made a set of ramps/platforms out of 2by10s last month. 4' ramps and then 'sections' of platforms..1',3',2' . This way I could remove the 3' center sections and gain good access to oil pan and inspect 'stuff'. My 2 speed selctor was a 'stick' behind left heel... PITA as up was low, down was high and of course heel ALWAYS caught the stick. I've since fixed it to 'low'. MUCH better torque, climbs hill better, just tortise slow.....
Jay
Phil Stier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil Stier Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 10:32am
I would like to revive this thread. I have just purchased an Allis Chalmers FP-50 forklift with a gas engine. It came with no battery. How can I tell if it’s 6v or 22v??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil Stier Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 10:35am
Twelve volt
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 11:02am
yup, 12 volt, reminds me I gotta put oil in mine soon.....
This page was generated in 0.119 seconds.
