7010 - Oil and smoke coming out of dipstick
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 - Oil and smoke coming out of dipstick
    Posted: 02 Mar 2025 at 10:59am
Haven't started the tractor since this fall.  Noticed that I have oil coming out of the oil dipstick.  When I removed the oil dipstick, smoke was coming out of it.  Breather tube doesn't have a lot of blowby coming out of it.  Tractor seems to be running just fine.  Sounds the same as always.  I am guessing my oil pressure is building up for some reason.  I also am not getting diesel fuel in the oil.  In fact, dipstick says I need to add oil like it is burning oil.
Not sure how to pinpoint the problem.  Any help is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2025 at 11:31am
Stand on the front tire and with a flashlite check the COOLANT level in the radiator. OK ?? or not OK ?? If OK, remove the blowby hose and wash it out with a power washer to be absolutely sure it is CLEAN on the inside. Triple check the engine oil level, making sure it isn't OVER FULL at all. OK? or not OK ??   If OK, install the dipstick fully and don't worry about it, BUT keep an eye on it for oil consumption, or fuel dilution.
