160 Ball Joint
FarmerJohn22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Topic: 160 Ball Joint
    Posted: 01 Mar 2025 at 2:20pm
The ball joint on my 160 won't stay in the socket anymore. It looks like the ball joint is supposed to be a replaceable part, but I'm having a hard time finding it. Does anybody have a source for it? Thanks.
1953 CA, 1950 G, 1970 160
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 3:55pm
If your mean the left one I use Case part # K207722 cut the old one off then drill hole in the rod weld the new one in or tap threads
pump grump View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote pump grump Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 6:20pm
The last two I got from Agco .
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 8:55pm
I’ve had good luck calling my AGCO dealer to find out if they are still available, if NLA they will search the dealer network to see if anyone has any and give me the phone number to call to purchase it. 160 parts are getting hard to find unfortunately but I have been lucky so far.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote pump grump Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2025 at 9:43pm
Farmer John 22 , did you find your ball joints for your 160 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2025 at 10:53pm
Not yet. Thanks to your and ACMan's advice, I called around to a couple of the AGCO dealers around. It took me a little bit to find one that was willing to help, but I talked to one today that is looking for the parts for me, so we will see how that goes.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2025 at 1:47pm
Cry If the world only standardized such things as ball joints.
Wink Sometimes you can get lucky anyway.Big smile In the early 2000's I needed one on the Knife drive of the Gleaner 1978 MH2. I had replaced one a week earlier on a 2 ton grain truck ( cannot remember if the 58 Ford, or the 60 Chevy ). The local auto parts had one in stock, and looked like it was the same size. They let me try it and fit very nicely.LOL So luck can be a real help some days.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote pump grump Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2025 at 7:37pm
I had good luck with Dale At FEH in Pendelton .
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2025 at 12:09am
Well I found a dealer that was willing to help me. It looks like a couple of the parts are still available, and they were able to find one of the other parts, but apparently they can't find the actual ball and pin part, or the ball cage, so I guess maybe I'll have to try to find a ball joint that has the same pin size that I can use.
