8050 Left hand door bottom glass
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Left hand door bottom glass
    Posted: 28 Feb 2025 at 12:52pm
Anyone know of a scrap yard that would have a bottom left hand door glass?
NLA from Allis Chalmers.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 3:26pm
Id start at Heitman Tractor
715 631 7022
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 5:48pm
Local glass company said if i could bring them a pattern they might be able to help me.
Will see Monday.
Heitman only had a complete door
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 5:53pm
We have a lower glass broken to. It’s got duck tape on both sides of glass holding it. But local glass guy said to bring him the door and he could do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 5:59pm
Is the glass just glued in? If the local shop can make one can i put it in? They didnt want to install it.
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 12:03am
If you have any pictures of the glass in the vinyl around it post them, I install commercial glass and some residential. Auto glass can be a whole different animal so to speak but I  may be able to point you in the right direction. I made up some glass for a buddies old pick up that had plate glass instead of safety glass. It has safety glass now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 6:36am
Glass is held in place with black urethane, exact same stuff as cars have used for 30 or more years. Installation is easy. Buy the urethane at Auto Zone in a caulking gun tube. Removal and cleanup of the old glass takes time.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 7:28pm
very easy to install a new glass, like doc said just get black urethane. I did a small front lower glass, local shop cut it out for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2025 at 8:23pm
Finally figured out the pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2025 at 10:52pm
Put some painters tape around glass on orange before removing to help keep it from scratching paint.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2025 at 11:21pm
My local auto glass shop gets slightly irritated if I try to remove glued in glass my self…
Can’t remember if they have a heat gun to melt the glue or if it is a special light (the name isn’t coming to me lol).
Glass isn’t cheap though, it figures around here at $35 per sq foot and that’s just the plain glass.
What did you do to end up that way? Get mad and kick it? Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2025 at 12:17pm
My grandkids get the blame for that kind of thing.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2025 at 7:39pm
Local shop, Bacon and Van Buskirk took the pattern i made and ordered a piece from there supplier. If it was a square or rectangle it would be around $90.
Will be a little more since it has a curve in it.
Hope its not much more. Should be in next week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2025 at 11:51pm
I’m curious how that will work out for you so keep us posted!!
Are you going to pull the door off so you can lay it down and do it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2025 at 7:14am
Leave it on the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2025 at 7:49am
I watched a windshield install on a newer John Deere on You Tube. So it can be installed with the door on the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2025 at 2:05pm
Definitely let it on the tractor, put a bead of urethane all the way around the mating surface then set the window up there with some pressure pushing it to seat well. Take painters tape and tape from window to frame to keep the window from sliding down or out of place. Urethane is tough stuff once it’s set up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2025 at 7:31am
Got the glass for the 8050. $166 for the glass, when they cut the glass they made 2.
Guess when they temper the glass some times they break? so they cut 2 and tempered both.
Going to install it next week and see how it looks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2025 at 3:48pm
Well, i was putting the cab filter back up there a was using a small line up punch to get it lined up. got the filter and frame back in and laid the punch on top of the cab.
It rolled off the roof and just hit the top edge of the glass, it sticks about a 1/4 of an inch, and shattered the window. Just enough to hit it. Whats the chance of that happening!
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2025 at 4:12pm
One more question, there is a black border around the glass, you can see it in the picture.
Is that primer on the glass?
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2025 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2025 at 7:46pm
It may be paint finished, or it may be the sealant behind the glass. If it is paint it may have been put on before they tempered it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2025 at 9:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2025 at 9:03am
Got the glass installed, all on all, everything worked out good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 6:38am
Great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 6:35am
Nice
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 1:22pm
Could you make it out of plexiglass or lexan? Tough stuff and don't have to worry about dropping your punch on it!! Lol. You can beat on it with a hammer. Buy a 4'x8' ft sheet and make several out of it. Cut it yourself with a jigsaw!
Edited by Ed (Ont) - 02 Apr 2025 at 1:49pm
