D17, 262 diesel valves
AintCheatnAintTryn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AintCheatnAintTryn Quote  Post ReplyReply Direct Link To This Post Topic: D17, 262 diesel valves
    Posted: 27 Feb 2025 at 10:29pm
Hi all, I'm having issues finding the correct valves for my D17. thus far I've come across a few kits that specify that they're for specific serial numbers and mine doesn't happen to fall into the range.
from what i can tell its a 1961 D17, SN: 29022D with the 262 diesel.
I'm quite new to working on old tractors so i don't yet know all the sites to checkout but I've only found valves for the 226 or when i do find valves for the 262, there are multiple options for both the intake and exhaust with differing dimensions.
if anyone would know where to look, a point in the right direction would me appreciated,
Thank you.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 11:08pm
Maybe try searching d19 diesel valve… think they’re the same if not someone can correct me.
Otherwise you could try Pfouts Family Farm, they seem to have a lot of different valves.
Heres a link with their info https://www.allischalmers.com/sources/index.aspx
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 1:31pm
Engine serial number will probably help you when searching for parts. It is stamped into a flat area on the block, left side, above the tach drive adapter, just below the head gasket/deck surface. There are differences between early and late D17 diesels, and also some parts exclusive to the turbocharged D19 262D engine. I got my exhaust valves NOS on ebay, and bought new intakes from Wengers’. I had to measure the valve diameter after taking the head off to make sure i got the correct intake valves…. Get familiar with AGCO’s parts lookup website and you can get a good idea of what the latest service parts listed for your engine are.
