New member needs help with M-100
Legdoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Legdoc Quote  Post ReplyReply Direct Link To This Post Topic: New member needs help with M-100
    Posted: 26 Feb 2025 at 7:11pm
Newbie from S. Texas here. I have a M-100 grader and need shifter boots which I can't seem to be able to source or match up. Also what fluid should I fill the transmission with?
Please help.
Thank you in advance.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 7:52pm
Link to pictures of Allis M100 Grader just for reference:
G
https://www.machinerytrader.com/listings/auction-results/allis-chalmers/m100/motor-graders/1048?srsltid=AfmBOopZuSzgSckZ_FiKbhGUJ-1N4b5Gk5iz3F4boLH7iolnx4_POjW4
Link to TractorData Specs
https://www.google.com/search?q=tractordata+allis+m100+grader&sca_esv=4b1e09beaa1370b6&sxsrf=AHTn8zrdjdx6kXoZWrHAYLje3Q1BwjPGsQ%3A1740621197729&source=hp&ei=jcW_Z77LKqnep84PqdD6oAk&iflsig=ACkRmUkAAAAAZ7_TnTP4EWhl3uNk8MD9pOaa0jWUuu_N&oq=Tractordata+Allis+M100&gs_lp=Egdnd3Mtd2l6IhZUcmFjdG9yZGF0YSBBbGxpcyBNMTAwKgIIADIFECEYoAFI-MIBUABY5J4BcAB4AJABAJgB0wKgAYcfqgEIMS4xMy41LjO4AQHIAQD4AQGYAhagAtQfwgIEECMYJ8ICCxAAGIAEGJECGIoFwgILEAAYgAQYsQMYgwHCAg4QLhiABBixAxjRAxjHAcICBRAuGIAEwgIREC4YgAQYsQMY0QMYgwEYxwHCAggQABiABBixA8ICCxAuGIAEGLEDGIMBwgIQEAAYgAQYsQMYQxiDARiKBcICChAAGIAEGEMYigXCAgoQLhiABBhDGIoFwgIMEAAYgAQYQxiKBRgKwgITEAAYgAQYkQIYsQMYgwEYigUYCsICDRAAGIAEGLEDGEMYigXCAggQABiABBiSA8ICDhAAGIAEGJECGLEDGIoFwgIREAAYgAQYkQIYsQMYgwEYigXCAgoQABiABBgUGIcCwgIFEAAYgATCAgYQABgWGB7CAgUQIRirApgDAJIHCDAuMTQuNS4zoAfKwwE&sclient=gws-wiz
Edited by Gary - 26 Feb 2025 at 7:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 8:04pm
Can’t help with your question.
But welcome to the forum
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 12:02pm
I used the rubber boots from the axle boots from a front wheel drive car.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 9:14pm
This is probably your best option - sometimes a random part number will surprise you and it's still available new from somewhere, but a lot of the parts for AC construction equipment are no longer available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Legdoc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2025 at 9:17pm
I appreciate the advice. I went to a CV boot sizing chart and found a semi universal boot for a '96 Acura that is trimmable that will work well.  TDH fluid will work.
Thank you again!
