Do they have fuel guages for allis chalmer b |
LiL B Orange
Topic: Do they have fuel guages for allis chalmer bPosted: 21 Feb 2025 at 12:51pm |
Do they have fuel gauges for allis chalmer b if they don't is it possible to install one?
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3980 |
Posted: 21 Feb 2025 at 1:00pm |
Most common gauge is a stick about a foot long!! LOL Otherwise, I don't think I have ever seen any other type of gauge for the 'B'
LiL B Orange
Posted: 21 Feb 2025 at 1:04pm |
Is it possible to Install an aftermarket gauge because I thought about cutting a hole in the top and install a marine 6 gal sending unit
ekjdm14
Joined: 20 Aug 2024 Location: Alsager UK Points: 987 |
Posted: 21 Feb 2025 at 1:11pm |
Anything is possible if you want to put the effort in, to be honest though I think you're best just carrying a dipstick with you & an extra 1 or 2 gallon can as a "reserve".
Just how much of a road trip are you planning, some kind of slow-paced scenic adventure? I'd likely only worry about a full on gauge if I were putting some serious miles in.
Edited by ekjdm14 - 21 Feb 2025 at 1:13pm |
LiL B Orange
Posted: 21 Feb 2025 at 1:15pm |
Not sure just alittle senic
adventure but it's dumb idea though |
ekjdm14
Posted: 21 Feb 2025 at 1:22pm |
LOL if you want to see dumb ideas you need to see the resurrection of my '41 B! Nothing wrong with having some fun & getting some use out of the old girl.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Thanks(1)
Posted: 21 Feb 2025 at 1:24pm |
The hand crank is the perfect fuel gauge. The length from the pulley spuds to the first bend is exactly the depth of the tank.
Les Kerf
Posted: 21 Feb 2025 at 1:28pm |
Ha! Why didn't I think of that!
DanWi
Posted: 21 Feb 2025 at 3:22pm |
I don't know anything about it, only remember my grandfather had a gauge that was a gas cap for his WD Allis. It stood 3 or 4 inches above the tank. A person could get 1 of the gauges like they used on snowmobiles, ATVs and lawnmowers. You have to look down on it from above and you would have to make an adapter to go from half turn to spin on.
rtwfarm
Joined: 26 Feb 2012 Location: nebraska Points: 1345 |
Posted: 21 Feb 2025 at 4:50pm |
Yes a aftermarket company made them for wc wd uc b and c’s
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 21 Feb 2025 at 9:14pm |
Could one out of a D series be adapted?
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1055 |
Posted: 21 Feb 2025 at 9:17pm |
Who knew! I'll have to check this one out! I carry a cut off yard stick and mark full , half etc. Aldo gave written 1 hr, 2 hr etc to mark my burn down |
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2231 |
Posted: 21 Feb 2025 at 9:43pm |
As Paul B said, the hand crank is the fuel gauge for a B C CA. I don't know for sure in the B C, but the hand crank sits perfectly behind the steering box bracket on the CA. But I can't remember the last time I used it to actually start either of my CA's.
Leon B MO
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1340 |
Posted: 22 Feb 2025 at 12:01am |
They should run all day on one tank of fuel, anyway my wd will.
Just fill er up every morning and you shouldn’t have to worry. There was a company that made gauges that you could read from the seat, I have one on a 45 gas… Doubt they’ll still in Business though.. |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5180 |
Posted: 22 Feb 2025 at 6:40am |
If you wanted to have an inexpensive "gauge", you could plumb a tee before the sediment bowl with a hose barb and attach a vertical piece of clear tubing to the outside of the tank. The top of the vertical tubing would have to be vented.
Edited by WF owner - 22 Feb 2025 at 6:41am |
Cernunnos
Joined: 30 Jul 2014 Location: Ridgeland, WI Points: 363 |
Posted: 22 Feb 2025 at 9:47am |
Here is a gauge I saw on a CA last year. However, I can't recall what company made it. It was similar to an older gas gauge on a snowmobile . It measures in 1/4 increments I believe.
55allis
Posted: 22 Feb 2025 at 10:00am |
Here’s the one on my 45..
AveryD12
Joined: 05 Mar 2018 Location: Foxworth.MS Points: 162 |
Posted: 22 Feb 2025 at 11:15am |
Wbecker had a post on Nov 23, 2016.
“Fuel gauge on my b gas tank”. He did an awesome job. |
AveryD12
Posted: 22 Feb 2025 at 11:30am |
I’m not sure how to post a link. I will try to post a screenshot
John426
Posted: 22 Feb 2025 at 11:34am |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 23 Feb 2025 at 9:59am |
I guess the gage would be fine but too much trouble for me. The ball peen in the tool box has worked fine since 1949. Hint....always fuel up before leaving the drive way.
Brian S(NY)
Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3383 |
Posted: 23 Feb 2025 at 7:16pm |
reminds me of a "measure" stick auto advertisement designed and graduated for the model "T" ford I found several in Dad's shop when he passed. Wonder if tractor implement companies ever made something similar. :) If someone wanted to they could run the tank empty then make a stick graduated to the 1/2 gallon as they fill with measured amount's :) inche square with each side for a different tractor :)
Les Kerf
Posted: 23 Feb 2025 at 8:58pm |
I have seen those measuring sticks advertised in the Steiner catalog
