electrolysis
AtuckerKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AtuckerKY Quote  Post ReplyReply Direct Link To This Post Topic: electrolysis
    Posted: 08 Nov 2010 at 1:27pm
I know that electrolysis will remove rust but will it remove any paint?
Farming looks mighty easy when your plow is a pencil, and you're a thousand miles from the corn field.    Eisenhower, Dwight D.
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 1:31pm
I have had good results . It may not completely remove all paint but will definitely loosen it. Located in Springfield, KY. Where are you.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote AtuckerKY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 3:35pm
I live in McLean Co in Western KY.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 3:41pm
I've thought about electrolysis but I don't think I could find a tank large enough to drive my whole tractor in. LOL!! Wire wheeling works good for me, just takes forever.
I live in London in Laurel Co. It's neat to see others form KY on here.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 6:53pm
If you use Sodium Hydroxide, it will definately remove paint.  One tablespoon per gallon of water.  I found the most pure stuff at Westlakes, labled Household Drain Opener, 100% Lye.  Comes in a 1lb plastic jar and mayve in 2lb also.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:22pm
usually about 3/4 of the paint will completely turn loose, the rest is much easier to remove as it has softened
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:23pm
this was using washing soda only
Ford 345C TLB
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:25pm
If you use washing soda (sodium carbonate) it will remove paint too. The paint will look like it is still attached but it will rub off or I just use a pressure washer.
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 8:22pm
Do you brush the sodium Carbonate on?  Soak the part? Etc?
Thanks
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 8:43pm
i use a little baking soda and the old paint will brush right off after a short time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 10:18pm
Dig a hole in the ground and line it with plastic for the big parts. The sodium carb goes in the water, then the part goes in and gets cleaned.
 When I take a part out I rub it on the wire wheel then rinse and there is nothing but clean metal left. You can put a part in with a half inch of muck and dirt and grease over the original paint and it will come clean with a light wire wheel touch and a rinse.
Edited by CTuckerNWIL - 08 Nov 2010 at 10:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AtuckerKY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 7:50am
Thanks for all the inputs.  Now I will tell you that I was asking so I could use it on a Farmall Cub!  I teach high school ag and we have one apart in the shop and I wanted to show the students about electrolysis.  PS I do use Allis on my farm.
This page was generated in 0.131 seconds.
