Calling all flooring experts……….
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Calling all flooring experts……….
    Posted: 13 Feb 2025 at 5:49pm
removing old linoleum flooring from off hardwood floor. This is the old ‘rolled linoleum’ I believe they called it, not the ridged hard tiles. Pulling the linoleum is the easy part, most of that 1/16” of paperish tar backing stays stuck to the wooden floor. What is the best way to prep the floor before the big ‘floor sander/finisher’ is used?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 6:05pm
Use a long handle scraper to remove the majority of it then remove the rest with mineral spirits and old rags. Just make sure you use adequate ventilation. You should have a beautiful floor when done. Some before and after pics would be nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 6:23pm
When I pulled up glued down carpet from 3/4 plywood, there were 'islands' of backing/glue. I used a 7" grinder with cup brush. It was fast,messy but DID THE JOB, once you got the hang of it. Knee pads are a must......
Since you're going to sand anyway...it might be worth a try ??
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 8:43pm
When I tore up some tile on top of hardwood flooring a few years ago, there was a section that the adhesive was very heavy. I ended up using a heat gun and putty knife (SLOW!!!).
Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 8:58pm
Spyder a brand of drill bits,saw blades makes a flat chisel blade that fits in the end of a Sawzall. On a jobsite a while ago a couple guys were doing just what you described
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 10:00pm
i had never heard of that Pat... I made something similar to use in an air powered chisle gun years ago... I will remember this !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2025 at 4:43am
Be careful with linoleum, some of it is full of asbestos... '60's to 80's year wise...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2025 at 11:02am
Yes, 10-4. Have a spray bottle of water to mist down the remaining paper-ish backing, keep everything moist while working with it. Have not used any type of powered sanders or grinders, just on my hands and knees with a putty knife, and a bucket of floor adhesive glue remover. Results are pathetically slow.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2025 at 11:50am
What do you get when a bomb goes off in a French kitchen?
Linoleum Blownapart.
Sorry
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2025 at 3:05pm
Sorry
I'm blown away by that one. lol
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2025 at 9:29am
Stopped by a flooring contractor yesterday, with a small sample of what I have removed. He said it appears to be ‘Congoleum’, claimed decades ago, the early versions of that did not have ‘backing’ on the rolls. It was installed by spreading a layer of adhesive on a floor, putting down a layer ‘tar paper’, then a coat of adhesive on top of that, then putting down the Congoleum on top. He said the try Mineral Spirits, be sure to have your windows open!!
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2025 at 10:19pm
Citrus degreaser, ZEP Big Orange comes to mind
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2025 at 3:34am
Once you apply a solvent to breakdown the adhesive, cover it with plastic or a flattened trash bag pressed down on surface to push out the air for a few minutes to allow the chosen chemical to work, the plastic will keep it from drying out or evaporating as you work the areas. Uncover as you go and use the plastic over till you are done. Just a thought as this is what I do when removing old wall paper. Good luck and we like to see pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 11:11pm
Some of the adhesives contained the asbestos more so than the actual rolled material , on tile it's the 9x9 tiles that were asbestos containing - wetting to prevent dust is accepted removal
  At school I was facilities manager at I had a 20 x 40 room I had to remove carpet from that was glued down . Got a motorized scraper with a 14" blade on front to take up carpet , but the glue used was termed Green Death and was a real chore to remove , used a orange based solvent to soften then blade again to scrape up slime of dissolved adhesive
