Allis Chalmers 7080 Hydraulic issues
cumsmk6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cumsmk6 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 7080 Hydraulic issues
    Posted: 13 Feb 2025 at 4:52pm
The 7080 I have is having surging issue that you can feel in the remote lever. It has the correct low stand by pressure and the correct remote output pressure sometimes.   Sometimes when you pull remote lever in cab, it works fine.
Other times you can pull remote lever and you can hear it surging/pulsating and almost feel basically in the lever.
Usually after the surging happens, you can pull remote lever and nothing happens then.
I’ve torn apart piston pump and it all looks well inside. I removed the priority valve in the rear by the remote valves in hopes to find something in there but nothing looks out of place.
Where can I look next for what’s causing my issues?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 5:16pm
Power steering always perfect ???  Until you unscrew the top sight glass (with the tractor on the level and been sitting for a time) you don't really KNOW if the hydraulic system is full of oil. Also, the stand-by pressure makes the hydraulic system work much better if it is at 600-650 psi, not 300-350 psi. Lastly, with the engine OFF, do all the remote levers "detent" into the raise position?? and also the "float" position ?? They must or you aren't getting full stroke on the spools.
Post Options Post Options   Thanks (1) Thanks(1)   Quote cumsmk6 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 5:48pm
Dr allis, yes power steering always works the way it should.     To increase stand by pressure, add more shims?
Also I’m gonna put remote assembly back together and look more into checking levers with tractor shut off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 5:50pm
Add more SMALL shims to the main pumps compensator. And check those remote valve detents.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cumsmk6 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2025 at 3:31pm
Dr. Allis,   Ok I’ve got my remote detents working correctly and I added small shims to get 600 psi on stand by pressure.   Remotes also have proper pressure now also.
I believe what has been happening all along is the hydraulic reservoir is being pumped into the transmission reservoir because after doing my testing/ adjustments on compensator, the hydraulic reservoir is low and the transmission is overfull.
I just had piston/ gear pump apart and replaced that internal pump seal so I don’t believe that’s where it is transferring.
Are there any quick fixes that you know of that don’t require pulling transmission to fix possible internal leaking seal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2025 at 7:14pm
The last tractor I heard of that transferred rear end (hydraulic) oil into the transmission had the radiator and oil coolers ahead of the radiator worked on and hoses got crossed up. If it wasn't transferring oil like that, (or that quickly) before you had the gear pump apart, something is wrong in that shaft seal area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cumsmk6 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 7:09am
Update on my situation for anyone interested. To solve my problem of hydraulic reservoir filling into my transmission reservoir. This is happening due to some internal shaft seals passing through the housings. Currently at this time, I’m not devoting that much time to a tractor I don’t use anymore.
So I drilled and tapped (1/4”NPT) the transmission and rear end drain plugs and connected the two together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 9:00am
You didn't know you had an oil transfer issue before removing the hydraulic pumps??   I'd still drain the transmission oil and remove the suction screen underneath and watch and see if the oil seal on the pumps drive shaft is leaking ?? That's not a terrible hard fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cumsmk6 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 7:27pm
No I didn’t know I had a transfer issue prior to tearing into this winter.   Last summer when I attempted to use tractor, it was pulsating in the remote lever ( kinda making noise from pump). So instead of properly diagnosing the problem, I assumed it was in piston pump. I was wrong, nothing was wrong in the pump. I’ll have to check that shaft seal.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 4:03pm
I’ve got a similar scenario, i just haven’t had time to work on it. Dealing with a 7010 that has similar symptoms as the original poster. More notably when cold, not often when hot. I’ve changed the transmission and hydraulic fluid, as well as the filters. Is there a process of elimination for determining if the problem could be solved by adding shims or adding a thicker gasket to the left belly filter?
Edited by CrestonM - 25 Feb 2025 at 4:03pm
This page was generated in 0.273 seconds.
