mag verses distributer |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3952 |
Topic: mag verses distributerPosted: 10 Feb 2025 at 1:32pm |
why does it seem like a mag lasts much longer without any attention compared to a distributer they both have the same basic componants
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88631 |
Posted: 10 Feb 2025 at 1:53pm |
most MAGS are 75 years old , back when things were built with QUALITY... compared to the newer distributors that are designed by COST ?????????
Les Kerf
Posted: 10 Feb 2025 at 2:43pm |
These magnetos reverse polarity through the points with each change of the magnetic polarity from North to South, etc. as it rotates. Any transfer of material gets reversed with each subsequent change. Distributors always transfer material in the same direction, and occurs not only at the points, but also at the rotor tip and cap terminals. In a distributor with breaker points, when the balance between the capacitance (in the condenser) and the inductance (in the coil) are perfect, there will be no transfer of material in the points. If you ever see this happen, do NOT touch it!
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5164 |
Posted: 10 Feb 2025 at 3:13pm |
Try to find any distributer parts today that are of the quality you could find 25 years ago. Magneto parts available ate this point are probably that old and when they're gone, they're gone.
dkattau
Posted: 10 Feb 2025 at 3:26pm |
Mags were probably built for a more severe environment than distributors.
Edited by dkattau - 10 Feb 2025 at 3:30pm |
HudCo
Posted: 10 Feb 2025 at 4:12pm |
60 years ago distributers still had to have regular maintance
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12024 |
Posted: 10 Feb 2025 at 11:44pm |
I beg to differ. I would take a Distributor any day over a Mag. I rebuild Mags, but I'm slowly moving away from rebuilding them due to the lack of good quality service parts. Quality parts for Mags have diminished. The cost to rebuild a Mag now a days gets pretty expensive depending on age, mfr. model, series & condition. With a Distributor, you can at least still get decent quality parts for them (non Chinese) as well as adding an optional electronic ignition. Like anything else mechanical, Distributors need to be attended to and inspected once in a while as well. Keeping a good EP Moly grease in the drive cavity is a plus to keep gear mesh wear to a minimum, as well as checking Distributor main shaft runout for peak performance. In most cases, a properly rebuilt Distributor top to bottom will give many years of service with normal intermediate inspections. I've changed over many a frustrated customer from a Mag to one of my Mag to Distributor conversion kits, and they never looked back whether points or E.I. Steve@B&B
