The Top Five
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Topic: The Top Five
    Posted: 09 Feb 2025 at 8:34pm
   Wow who would have thought?
The votes are in, the numbers tallied, and the WINNERS announced:
The top 5 cheapest DIESEL trucks to own all hail from the same automaker.
     General Motors makes the top 5 cheapest DIESEL trucks to own.
   -- judged on their AVERAGE ANNUAL MAINTENANCE COSTS
   1st Place: Chevy Silverado 1500   $714 / mo.
   2nd Place: GMC Sierra 1500      $727 / mo.
   3rd Place: GMC Sierra 2500HD    $912 / mo.
   4th Place: Chevy Silverado 2500HD $936 / mo.
   5th Place: Chevy Silverado 3500    $1,109 / mo.
I find it very impressive that a Chevy Silverado 3500 ( 1 ton ) could
beat out the competition FORD and RAM 1500 Series ( 1/2 ton )
And as everybody knows, the GM Duramax Diesel requires DEF
    CONGRATULATIONS GENERAL MOTORS -- JOB WELL DONE
Gary
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 9:16pm
LOL.... You expect FORD to win a VOTE made up of 90% CHUBBY owners ???  LOL
Edited by steve(ill) - 09 Feb 2025 at 9:16pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 9:59pm
Are you actually suggesting that the vote might be a little bit one-sided ?
   Nooooooooooo   they wouldn't do that, would they?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 2:30am
Garee, I have a 342,000 mile 99Ford SD250 7.3, routine maintenance every 5000 miles, twice installed under valve cover wire harnesses, a fuel filter heater plate and swapped turbos at 341,000 as felt could be due. Had the OE starter fail at 341,000.
BP Know of NO ONE here with a Duramax that has not changed all fuel injectors at least twice in 250,000 miles, always leaking always something electronically failed. Cannot keep seats in the trucks as foam collapses(My Ford are OE and sit Excellently), also seat drive adjustment systems in the GMs routinely fail.
All the 99 and later trucks corrupt as been hit by rust bombs, reminds me of the 1970s GMs and IH trucks the engineers have not learned from.
GM and Ford adopted the same Boxed Frame design in last few years, both brands rust from inside out and self destruct the chassis at rear of cab routinely, know that from local body shops. Ram adopted super stiff chassis and are now seeing chassis cracking, so is actually no decent truck on the market any further. And at a cost of no less than $70,k
I
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 6:35am
I have a cousin that has one of the 1500's with a diesel engine, who would probably not agree with your "poll".
It has been at the dealer for 3 months (just after Halloween). It had been back several times for excessive oil use and, finally, the engine refused to start. They loaded it and took it back and it has been there since. He told me his car has 250,000 miles and is at the point where he doesn't really trust it to go on a long trip and he is making payments on a truck he can't drive.
I guess I would agree that his cost of operation for the last three months had been low!
Google "Chevy Silverado 1500 diesel engine problems". You will come up with a lot of reading!!!
I don't put much faith in these 10 worst tractor or 10 best lawnmower online articles. Most, including Consumer Reports polls, are geared to achieving results they want ($$$).
By the way old buddy, do you still wear those underwear with bowties on them???
Edited by WF owner - 10 Feb 2025 at 6:37am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 8:33am
Hey Curt
How did you find out about my Bow-Tie Underwear?
Did your wife tell you? LOL
Sure wasn't my wife, she wasn't at the GOTO. Maybe it was Larry!
I guess I just have Chevy blood in my veins.
The most miles I have ever put on a Truck was a 2001.
Traded in 2008 with 97,000 km for my first Duramax.
Driving Duramax ever since. Just put the key in and go.
   Get out of the way FORD - I'm coming through
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 8:43am
I had a 1989 F250.. drove it 250K miles and sold..... bought a 2001 F150 and drove it 250K miles and sold.... Bought a 2002 F150 and drove it 250K miles and sold... have a 2013 now with 100K miles.......... Never have had much problems, thats why i keep driving them ..... 97K km is NOTHING..( thats 60K miles .... i dont consider a truck even broke in untill it hits 150,000. )
Edited by steve(ill) - 10 Feb 2025 at 8:46am
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 11:02am
Gary
  No mention of the DOT putting out a bulletin on chevy gas truck engines grenading.
  Law suit in the works for yrs.
  Are you in high school???
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 12:47pm
Never Green
How about you start over by going back and reading the Post from the beginning.
Clearly stated at the beginning, Pick-up Trucks with Diesel Engines.
Nothing to do with Gas Engines.
But yes you are correct. GM does have an issue with there 6.2 litre Gas Engine that was used in Sierra and Silverado Pick-up Trucks.
I believe I read somewhere that the Oil Supply to a Crankshaft Bearing is somehow related to the Engine Ignition switching to only 6 cylinder or 4 cylinder modes.
Trying to figure out your question about High School.
Were you thinking of going back and continuing in to High School?
Bet it would do you a lot of good.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 1:00pm
Never Green CLEARLY STATED that he was bringing up GAS ENGINES in the CHUBBY trucks......Not a NECESSITY to follow the original post 100%.... You veer off topic CONSTANTLY with your posts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 3:13pm
More like Jr High now convinced.  HAS NO CLUE as to What engines and what sizes unless moves to WIKI to find them, and then trusts the CONS at WIKI that were proved NOT Experts but Opinion based References.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 8:11pm
Dave
You are partly right. I totally forgot about the 3.0 litre Diesel that is available in the 1500 Series.
When I think of Diesels in GM Trucks, I only think of the 6.6 L
Maybe because that's what I've been driving since 2008.
And 'Top Speed' didn't specify if the 3'0 L was in the 2 1500's.
Otherwise I think I have a pretty good knowledge about GM Engines and sizes.
G
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 12:35pm
Ah the February doldrums. Long winter. Cabin fever. Bored. I KNOW! Let’s start a truck argument!!!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 1:12pm
Yup TBone I would agree with you 100%
Dave and Steve in the Snow Belt all cooped up and bored.
So for entertainment decided "lets pick on Gary"
-- even though this is not even the So-Called Political section.
I'll bet Darrin is really pleased with the way his Forums have evolved.
Me on the other hand, no chance of Boredom here.
Spending the Winter down South on the shores of the GULF OF MEXICO.
Less than 100 feet from an MT Sandy Beach.
Have had days of setting record highs in the 80's
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 1:17pm
pick on TDS Garee ???  Not needed... Your ignorance puts you in the spot light every day... Go drink some ANTIFREEZE .... and get that STARTER PUSH BUTTON installed !!  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 1:23pm
G
Yeah that political section “border rules” got blown out of the water a long time ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 1:44pm
G
  Why are you throwing Darrin under the bus???  Yep, every one is picking on Gary, I  figured you would not understand the high school quote.
      Gees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 2:52pm
Y'all be good, or gaREE will tell teacher on you!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 4:46pm
Can still remember the Mid to Late 70s GMs, rusted so bad could HEAR them corrupt at night, my 1977 K20 had ZERO paint remaining in 1979 on the underside of the bed and was beginning to crumble away.  The 350 in it ran great, only ate a quart of oil between 3000 mile changes since Day One, terrible Valve Guide Seals in those days.
Edited by DMiller - 11 Feb 2025 at 4:47pm
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2025 at 1:39pm
Yes they sure did rust back then. But not only GM. Others were just as bad. I towed Fords to the wrecking yard where I worked part-time with the box sides totally gone!! Two and three year old trucks. Lot of people in our area oiled their vehicles heavily at that time. My friend ran an oiling business for years - at the time only used engine oil or any old oil was applied. In our area roads are heavily salted all winter. Really makes it hard to keep a vehicle from rusting but oiling helps a lot.
Edited by Ed (Ont) - 12 Feb 2025 at 1:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2025 at 1:43pm
Gary are those figures cost of buying the truck and maintenance for a certain time period? Or just maintenance costs? Smile
Gary View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2025 at 7:26pm
Ed
Here is the message 'Top Speed' noted at the beginning of their report.
In compiling this article, we have cross-referenced information for vehicle reliability, maintenance, and pricing from sources like J.D. Power, Kelley Blue Book, Edmunds, RepairPal, CarEdge, and Consumer Reports to give you the most up-to-date and accurate information possible. Please note that we have ranked the following models based on most reliable to least reliable. Please also note that the recalls are with regard to how many have been in the current generation.
The dollar figures posted are the average ANNUAL Costs (not mo.) over a 10 year period.
The Engine in the 2 1500 Series was the 3.0 litre Turbo Diesel.
The #6 if added to the list is the Sierra 3500 at $1131
and then finally #7 the F-250 at $1241 and #8 the F-350 at $1295.
Must be beyond FORD's capability to install a Diesel in an F-150 LOL.....
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2025 at 8:10pm
Or maybe Ford doesn't want to have their customer's vehicles for four months waiting for parts. It's pretty easy to have low operation costs when the truck is setting broken down on the dealer's lot. They don't use much fuel sitting on the lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2025 at 9:10pm
Happy Laughing Sticker - Happy Laughing Lol Stickers
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 8:19am
Curt
You could have a good point there.
Looks like L'il Stevie liked it anyway.
Apparently they give real good milage when they do run.
My Salesman told me one time about driving one to Montreal and back.
Averaged over 30 M/G
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 2:31pm
Curt
G
you believe EVERY salesman, dontcha, gaREE!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 4:24pm
Yes they do get that mileage when driving empty at steady speed and not towing!!! Some good info here but too bad that some want to make this into some kind of peeing contest! I thought this was a fun site but seems that some now are on some sort of personal vendetta. What is that about????
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 4:55pm
I agree 100%.
Both steve(ill) and Gary are valuable members of this forum. Both have contributed some great info over the years. I don't know what started this controversy, but guys, enough is enough!
We are all here because we like AC tractors. Can't you guys put your differences aside and be civil to each other?
I do not participate in the Politics section, but I assume that is where this stuff all started. That section is the worst thing that ever started on this forum.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 7:50pm
I agree with you 100% Curt.
And I can tell you exactly when it started.
It started a few months back when SteveILL replied to a New Member who posed a
question about replacing the seals in the double acting cylinders from a 400 Series Loader.
SteveILL replied and went in to great detail about replacing the Chevron Seals in a typical WD loader, unscrewing the large cast end, removing the Chevron seals etc. etc.
I replied and pointed out to Steve he was totally wrong in what he posted and the 400 Series were nothing like the WD cylinders.
I believe I made some comment pertaining to how important it was to know what your talking about and even having experience in what you are talking about.
Well that didn't go over well with Stevie and that is when the name calling and ignorant comments started.
Over time the select few regulars from the Politics started to join in with their similar comments.
Another of my comments that instigated even more was when I replied to one of Steves comments to another New Member that the D-10 and D-12 basically replaced the Model B
When I pointed out that I thought he was wrong and there were many other Allis Model Tractors in between.
This is the way I recall the progression, but you can expect SteveILL to come back with a totally different response.
Sincerely
Gary Soper
Peterborough, Ontario
CANADA
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 8:32pm
TDS, your comments on ANTIFREEZE and STARTER PUSH BUTTONS were both WRONG.... this has NOTHING to due with what i posted about tractors.... TDS Gareee is constantly pissed about what i post ( and most others) in the Political Section and he carries it over into the tractors...... Let it GO...  TDS.... your comments in the tractor sections should NOT be related to your opinions in the Political section...  EVERYONE  of us ( except you) can post in the Political and disagree, then comment in the tractor section and have no problems....... LET IT GO !
