8030 Idiot lights
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 8030 Idiot lights
    Posted: 08 Feb 2025 at 9:34am
8030 FWA Powershift.  When I turn the ignition switch to the "on" position, which dash lights should come on?  None of mine light up.  When I push the test button, all the lights do come on.  Can I assume that the sending units are bad?  When running, sometimes the trans oil pressure light will come on intermittently.
The tractor is pretty new to me and starting to go through it and address some issues.
Thanks in advance!
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2025 at 9:41am
The volt lite far left side and the engine & trans pressure lites. I found the white wire harness that plugs into that assemble on the back side of it can cause trouble. Dave
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2025 at 9:47am
A factory service manual is your best bet. It tells exactly how the warning lights work and how to test them If you are not familiar with the tractor id get a operators manual too
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2025 at 9:48am
Do you mean the harness that plugs into the back of the lights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2025 at 10:01am
Already have both factory manuals.  Tractor is at my mechanic's shop. I will get him to check the wiring harness out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2025 at 3:36pm
Dave:  How did you solve the problem?  Was it just 1 wire in the harness, or the entire harness?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2025 at 1:19pm
Can't honestly tell what the exact problem was, goofed with for more time than l,d like to a admit, ended up pushing wire connector part way on the circuit board in order to get all lites off again except trans filter lite witch I went after in the first place.( that lite had on been on for about 20 years) Long story short a couple weeks after planting season went to move tractor and no lites came on, so pulled instrument panel off and found the wire connector plug had fallen off, now I was a little peaved so slammed it back on with more force than was necessary stuck the panel back on went to start tractor and be darn if 3 lites came like it should. thats been over a year ago. Dave
