Starting a 6 volt tractor on 12 volt
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Starting a 6 volt tractor on 12 volt
    Posted: 05 Feb 2025 at 5:45am
Guys I need to get my C high crop running and move it. It’s been sitting in my shop for several years.
I need to start it and run it but do not wish to buy a 6 volt battery at this point.
It is magneto fired. Can I start it with a 12 volt battery and not hurt the generator?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 5:49am
I'd take the wires off the generator.  Then you'd be fine.
AaronSEIA
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 6:09am
You will be fine. I have a 6 volt WD that is my "parade tractor". it still has the 6 volt generator, but I have used a 12 volt battery for many years. The generator is more of a fan belt tightener at this point.
I charge the battery a few times through the year. The generator does still put out some charging.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 6:47am
I've never needed to but have been told-don't grind the 6V starter too long at a time on a 12V battery.  Otherwise, it's fine.  Don't turn on any lights if you have them on a 12V battery.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 8:21am
Change the bulbs to 12v, slap an alternator on it, drop in the 12v battery, connect it as negative ground and live on.
All my B's, WD, and WCs run 12v batteries on the original 6v starter.  It has been my experience that the 12v battery will throw the engine over with more authority, but you certainly won't 'hurt' it.  The Delco motor is series-wound, as the motor speed increases, it's internal inductive reactance (of the armature) conveniently limits current flow, so it cannot overload or overspeed.  What you MIGHT find, is that years of use has made the starter helix and pinion worn... having a sprightly start might reveal that age, so popping the unit out for a cleaning and inspection would be wise.
On my 'big red' JXLD (338ci inline six) driven generating plant,  Hercules spec'd the unit with 24v start.  When I went to convert it to 12v, the same part number was identified for 12v... and 8v.... and 6v.....
Would I want to start it on a 6v?  Not unless I was to use really short, really fat cables... but in looking around, I found many cases where they DID.  The starter simply didn't care- it was built to handle the current of a low-voltage start, and it limited it's current based on cranking load and speed.  That big beastie doesn't crank hard... it's just big... with a big generating head connected.
Edited by DaveKamp - 05 Feb 2025 at 8:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 8:24am
starter will work fine on a 12v battery...  6 v generator will put out about 18v max when not connected to a battery.. I use one to charge a 12v system with a voltage regulator instead of the light switch... that being said, just take the "A" wire off the generator and tape it up.. No problem !!
Edited by steve(ill) - 05 Feb 2025 at 8:25am
