G Head Observation
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Topic: G Head Observation
    Posted: 02 Feb 2025 at 1:48pm
What do you think caused all the pock marks on the head? The piston looks good, but I'm sure they are not the originals. Only on 1 cylinder. Also found a little piece of 5/16" bolt with a offset hole in it lodged in one of the cooling ports. Most likely from an easy out, but what was it doing in there?
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 2:27pm
Looks like that cylinder had water or coolant leaking into it, and sat that way for quite a while at some point in it’s long life.
Edited by RedHeeler79 - 02 Feb 2025 at 2:31pm
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 3:37pm
Agreed, looks like corrosion damage from water. What piques my interest though is the "tree rings" pattern barely visible on that part of the head.  How high up do the pistons sit in a G? Wouldn't imagine the compression ratio was that high that it'd be a corroded impression of a piston sitting at TDC for years, so I'm wondering if it let a rod loose one time and the piston kissed the head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 4:02pm
The tree rings you’re seeing are marks from the cutter head on the surfacing machine at the machine shop. They used to leave a slight texture for gasket sealing, but with the newer MLS style gaskets they usually leave a more smooth, almost mirror like finish. —-on closer inspection, i see what you’re talking about, and it’s probably the area where the fire ring sealed against the head—- see that it follows around the combustion chamber
Edited by RedHeeler79 - 02 Feb 2025 at 4:05pm
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 6:06pm
5/16 bolt piece was from a manifold stud into the water jacket someone was trying to get out
Edited by JoeM(GA) - 02 Feb 2025 at 6:07pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2025 at 7:12am
What I'm seeing is all through the pitted part of the head, not in line with the machining marks but perfectly concentric with where the bore would be & going all the way in to the center. That's why I thought maybe residue from a piston kissing it as the marks look just like the machine marks you see on the crown of a piston.
Like I say, barely visible but just in the area where the piston could've touched. You can see it better in the close up shot, easily missed on the first photo.
Edited by ekjdm14 - 03 Feb 2025 at 7:13am
Post Options Post Options   Thanks (1) Thanks(1)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2025 at 12:26pm
I see that now… it does look like the machine marks in a piston crown of a flat-top piston. Your theory may be right. I’m assuming a G engine is not a power crater piston since the combustion chamber is in the cyl head. Never taken one apart. Perhaps ever so slight contact?
This page was generated in 0.043 seconds.
