G manifold nuts
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Topic: G manifold nuts
    Posted: 02 Feb 2025 at 1:30pm
Anybody here have a good way to get the 2 middle manifold nuts started? I can get 1 of my fat fingers up in there and they always just fall on the floor. Made some new words up yesterday trying to get them on. Probably not the smartest thing to do, but I lifted one side with the gantry so the nuts wouldn't immediately fall down.
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 1:47pm
It is a lesson in humility, and humiliation!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 1:48pm
can you use a socket, put tape inside to hold the nut ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 1:52pm
No. You can barley get the closed end of a combination wrench in there and maybe turn it a few degrees.
CWiltfong2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CWiltfong2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 2:02pm
I've done several over the past few years. I start the outer ones but leave them as loose as possible to allow more room in the middle. Pretty sure I even removed the distributor and carburetor as well.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 2:45pm
My 14 year old Grandson often gets drafted for this type of project, before he was born his Mama got the call. Grandson #2 should be available for another ten years or so :-)
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2025 at 11:48pm
If the threads are clean and easy to start without the manifold in the way then put the manifold back on and put the nut on a long smooth drift punch roughly the inside size of nut, line it up with the stud and spin it on with a long thin screwdriver as far as it will go being sure you don't cross thread it then finish tightening with a wrench or socket. When I can't get a bolt or nut to stay in a socket I put a small piece of paper over the edge of the socket business end then push bolt or nut into socket and get it done then wiggle socket or pull off with needle nose pliers. HTH
Shady Grove farm 22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shady Grove farm 22 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2025 at 12:52pm
I have put a drop of super glue on my finger then glue the nut on. it does take off any skin to pull it loose.
My hands are big, there are some places they just don't fit
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2025 at 4:45pm
If you have the space, and can find a bit of hose just big enough to slip the nut in, it can start it, too.  Either way, its no skin offa MY, er, a finger...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2025 at 7:02pm
I sometimes a magnet to hold small parts in place while manipulating nuts/bolts. Without being there it is difficult to know just what works best though.
Good luck! Smile
This page was generated in 0.046 seconds.
