D-17 ignition
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: D-17 ignition
    Posted: 01 Feb 2025 at 1:47pm
working on a 63 D-17 gas  it has a alternator instead of a generator and is hooked up as 12volt negative ground currently,  i think they were suppose to be pos ground,   or do they need to be 12volt neg ground with a alternator?
the coil is currently wired for pos ground
Edited by BLee Mn - 01 Feb 2025 at 1:48pm
Cowboy UP
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 4:29pm
I converted our D17 IV to an alternator, negative ground. It used to be positive ground with a generator from the factory. Sounds like yours was converted.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 5:23pm
Originally posted by BLee Mn BLee Mn wrote:
... do they need to be 12volt neg ground with a alternator?
Almost all alternators are set up to be Negative Ground.
In theory they work better if you wire them for negative ground, but on low-performance engines like this it is likely that you couldn't really tell the difference.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 5:57pm
On Neg. ground systems, the wiring to the Coil is as follows:  Plus (+) side of the Coil to the Ignition switch. (IGN) terminal  minus (-) side to the Distributor.  If you have it still wired for pos ground, switch the wires around. You'll be good ta' go....  Thumbs Up
Steve@B&B
