better of the two
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: better of the two
    Posted: 30 Jan 2025 at 9:33am
assuming rules allow  what tractor will make the best puller wd45d with 262 gas or series 1 d17d with 262 gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 10:27am
D-17 chassis gives you three speeds to use: 2nd low.....3rd low.....2nd high.  All you've got on a WD-45D chassis is 2nd and that is exactly the same as 2nd high on the D-17 chassis. The D-17 chassis will be about 500 lbs heavier, so there is that to deal with.
