Late model 8000 series speed |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 663 |
Topic: Late model 8000 series speedPosted: 26 Jan 2025 at 12:01pm |
I have a late model 8070 fwa. Its my understanding there was a ratio change in the drive train in some or maybe all of the later tractors. Does anyone what know the speeds were on those tractors. I cant find that information anywhere
Thanks |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8729 |
Posted: 26 Jan 2025 at 12:40pm |
The change was in 2WD units. FWA was always faster like 30's and 50's. Testing showed the narrower faster finals would hold up in 2WD 8070's so at #2662 the change was made. Can't tell you the numbers. I think they were just using up 7080 parts before the change.
In Norm's book.
Edited by SteveM C/IL - 26 Jan 2025 at 12:42pm |
DrAllis
Posted: 26 Jan 2025 at 12:50pm |
Latest model 8000's had a faster LOW range. I don't have the numbers but I do know 5th gear was in the 6.0 to 6.2 MPH area, so it was 10% or 12% speed increase. The negative was 1st gear may have been 2.0+MPH instead of less than 2.0 MPH. The change was made at 8050 s/n 2814 and up. 8070 fwa was s/n 2359.
Edited by DrAllis - 26 Jan 2025 at 4:12pm |
DrAllis
Posted: 26 Jan 2025 at 3:57pm |
Some quick math comes up with this: Old gearing of LOW range Power Shift trans: 2.0-2.7-3.7-4.7-5.8-7.3 MPH. New LOW range gearing only in the last year or so of 8000 series as I remember it. Effective at certain s/n's: 2.1-3.0-4.0-5.0-6.2-7.8 MPH. This is at 2300 RPM with 20.8 x 38 rubber on an 8050/8070 fwa chassis. Now, 8070's rated speed was 2400 RPM so its actual speeds are a little faster yet.
Edited by DrAllis - 26 Jan 2025 at 4:10pm |
8070nc
Posted: 26 Jan 2025 at 7:15pm |
Thank you for your time Doc. My serial #is 2854 if i remember right. I know its over 2800
1984 80780
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2206 |
Posted: 26 Jan 2025 at 7:55pm |
We have gps setup for all the 80##. The 8070 pd with 20.8x 38 will go 20.4 on the hwy. The ps 8050 and 8010 with 18.4 will top out at 19.ish
Leon B Mo |
