Automated my snowblower shute
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Topic: Automated my snowblower shute
    Posted: 24 Jan 2025 at 7:04pm
135 RPM hydraulic motor. Now I can stay warm in the cab instead of getting out to turn the handle.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 7:10pm
Nice! Now you need to come do mine
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 7:44pm
I have seen Windshield Wiper Motors used to turn Blower Shutes because of their very slow RPM.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 8:09pm
I put a steering wheel on the one I made, telescoping shaft, too...Thumbs Up
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 11:05pm
Very nice. 5 Stars
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 7:32am
FWIW.....if you swap rear wheels, you'll have better traction....
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 9:32am
I like it! Nice install.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 3:01pm
135 RPM
Are you broadcasting the Snow like you would Grass Seed?
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 4:46pm
That speed motor seems about perfect for controlling the chute rotation and direction. Very similar to the hand crank speed.
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 6:17pm
12 volt window motors quite common retrofit on garden tractor sized snowblowers, not sure if they would up to the task on a heavier blower like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 1:53pm
Ingenuity strikes again!!  Lookin' good!
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 5:51pm
Doubt that a 12v window motor would have enough torque for that large of chute.
Hydraulic motor would be the best route to take.
I adapted an early GM power window motor/gear to the snowblower on my JD GX345.
A bit of work, but it moved the chute easily.
Rather than letting the motor stall out at the end of travel, I built a spring-loaded clutch
to protect the drive; adjusted to just slip when it hit either end of travel.
Also used a 12v actuator for the deflector; stock item at Surplus Center.
(video taken before cab installed)
BTW, the GX345 w cab, mower & snowblower is for sale.  PM me for info.
Edited by Gatz in NE - 28 Jan 2025 at 8:58am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 7:25am
I still have the hand crank on the chute turner for my snowblower, but I recently used a 12-volt linear actuator with a double pole, double throw momentary switch to tilt the tip of the chute up or down.
I was more concerned about the tip, since I could easily turn the chute from the seat but had to shut everything down and get off every time, to tilt the chute.
Joe D15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe D15 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 12:30pm
I have been looking for something like that for on my PTO powered snowblower. Since 1977, the 170 and a Badger Snowmaster has been our go-to machine to move snow. As the years have gone by, it's getting tougher being out in the mis directed snow.
With getting a new-to-me 6080 with a cab, I need to fab a system for rotating the chute. I was torn between a hydraulic motor, hydraulic cylinder, or a 12 volt gearmotor.
This will be my project before next winter. I'll try to post some info and pics as it goes along.
Thanks,
Joe
Dad's '52 CA, '68 170
My '61 D15, '85 6080
Was Joe in Manty
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 12:36pm
guys have used cheap 'ATV' 12v winches to rotate chutes.....
possible 'clean' option ?
