WD crankshaft parts |
SteveRogers
Joined: 21 Jun 2023 Location: Geneseo, IL Points: 23 |
Topic: WD crankshaft partsPosted: 23 Jan 2025 at 3:12pm |
The crankshaft pulley does not appear to be broken in any way. But there is another part that goes over the top of the pulley and has 4 set screws that attach it to the pulley. What is this part for and how do I know what the tolerances should be or how should it be adjusted to the crankshaft pulley?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: 23 Jan 2025 at 5:22pm |
That is the pulley used in the Charr-Lynn power steering kit back when you could but a complete setup. You can use a factory p steering pulley instead if you can't get the 4 set screw add on to work.
SteveRogers
Posted: 23 Jan 2025 at 9:49pm |
So I think that the bolt fell out for some reason. I plan on trying to just put it back on with a new bolt. Is there any reason that won't work or a problem I'm not thinking of?
DrAllis
Posted: 23 Jan 2025 at 9:52pm |
The bolt that secures the OEM crank pulley to the crankshaft snout is a special pointed nose bolt with an Allen head to fit under that power steering pulley that was added on. If the tractor doesn't have power steering anymore, remove that add-on pulley.
Kenny L.
Posted: 23 Jan 2025 at 10:17pm |
I thinking it take a special bolt with a locking nut if I remember right, but it has been awhile ago when I had to redo one, I'll look and see if I've one on the parts shelves if I remember the next time I'm in the shop.
Edited by Kenny L. - 23 Jan 2025 at 10:21pm |
SteveRogers
Posted: 24 Jan 2025 at 8:09am |
Thanks for the information. Thanks for checking to see if you have one. If you don't, do you have any idea where I might find one?
DrAllis
Posted: 24 Jan 2025 at 9:37am |
Is there power steering on the tractor??? yes or no ??
SteveRogers
Posted: 24 Jan 2025 at 10:21am |
yes
DrAllis
Posted: 24 Jan 2025 at 10:25am |
OK. So, you must use the setscrew and jam nut required to use the power steering pulley. You cannot use the original setscrew AC used, as it is too tall.
SteveRogers
Posted: 24 Jan 2025 at 10:27am |
Ok, thanks. Any ideas where I can get one?
SteveM C/IL
Thanks(1)
Posted: 24 Jan 2025 at 10:40am |
search WD45 crankshaft pulley....you can buy new 2 groove pulley with set screw. Don't cry about the cost. Be glad it's available.
SteveRogers
Posted: 24 Jan 2025 at 10:51am |
Thanks, I was beginning to think I might have to do that.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 24 Jan 2025 at 11:18am |
The original WD-45 Factory 2 belt Pulley for Power Steering is 70 227395. The Setscrew P/N is 70 918410 G |
Kenny L.
Posted: 25 Jan 2025 at 3:59pm |
does your pulley look like this on.
SteveRogers
Posted: 25 Jan 2025 at 7:53pm |
Yes exactly. Is there any special way to set the Allen screws?
SteveM C/IL
Posted: 25 Jan 2025 at 9:16pm |
I'd assume you keep working with it until you get the least wiggle wobble out of it.
ekjdm14
Joined: 20 Aug 2024 Location: Alsager UK Points: 987 |
Posted: 27 Jan 2025 at 7:55am |
I suppose in theory you could chuck it up in a lathe & clock the OD of the pulley groove but not likely to be THAT critical. Main issue would be locating/making a suitable set screw to hold it in place. Assuming the snout of the crank/ID of the pulley are still good I'd probably consider tapering the end of an Allen set screw to engage the crank & fit with red Loctite along with the lock nut which may have been lost originally (But then I am notoriously cheap & it might be "safer" for the crank long term if you bought the correct 2-groove pulley just in case there was something going on with the original).
Edited by ekjdm14 - 27 Jan 2025 at 7:58am |
Kenny L.
Posted: 27 Jan 2025 at 12:41pm |
If it was me I would buy the factory pulley, the char-lynn pulley has a tenancy of the set screws coming loose. I got the set screws I use from a farm store and use lock nuts, you must try and get it centered and have the pulleys line up also ( it can be a bear cat) as you can see I put some weld on this one. I'm pretty sure that the setscrew P/N 7091840 is NLA I had my weld shop make me some from setscrew I got from a farm store. HTH
DrAllis
Posted: 27 Jan 2025 at 1:43pm |
I'm skeptical that the nose of the crank and the pulley that spun on the nose of the crank are much good after all of that.
