How much power to pull a chisel plow?
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: How much power to pull a chisel plow?
    Posted: 07 Nov 2010 at 6:53pm
What size tractor (in horsepower) to pull a Glencoe 9-shank chisel plow with 4 in. twist shovels?
Thanks for your input!
Thanks & God Bless
Dennis
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 7:01pm
Depends on how fast you want to go! 170hp 220 @6.8mph.Cousin uses a 100hp 190 and looks like he's crawling.Both 9 shank/4in twist Glencos.
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 7:43pm
I would like to see a minimum of 15 pto hp per shank in our conditions in southern Pa.
A 10 shank will make my 7060 sit up and beg.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 8:27pm
Around here you'd want an 8050 FWA.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 10:00pm
I pull a nine shank 1600 about 11" deep with my 190XT, 38" radials, pie weights, no fluid.
ALLIS EXPRESS!
This year:
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 1:39am
I have 2 11 shank kewanee chisel plows, both with 3.5" twisted shovels. I can pull them at a depth of 12" with my 7040 7060 or 7080. My 7040 (136hp 20.8-38 duals, fluid, no weights) will pull it in low 3rd high. My 7060 (210hp 18.4-38 duals, fluid, 1000lb on each rear wheel) and 7080 (210hp 20.8-38 duals, no fluid, 1000 on each rear wheel) will pull them in low 4th high. All three of them have the PD trans. A disc chisel will take a few more ponies. I pulled an 11 shank glenco 4" twisted with a 6215 (215hp 18.4-46 duals) fwa White for a buddy with no trouble.
Edited by Dans 7080 - 08 Nov 2010 at 1:44am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:07am
I pulled a Krause/MM 9 shank all the way in with a 190XT. 3" or 3 1/2" twisted shovels in 5th gear (aka 3rd high).
Wink
I am a Russian Bot
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 8:16am
I would say minum 135 hp. in your country depends on how deep,
 I pull 7 shank w/ 4" twisted 11 to 12" deep about 5 mph w/ 7000 black belly in spots it works, Just keep your tractor Happy, and your wallet in your pocket, better safe then sorry.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 9:25am
We pulled 11 shank twisted shovels with our 220 last spring in 4th. Cant remember the MPH but our tractor has fast low range, almost the same as 5th I think 5.8? This was 8-10" deep. How many you can pull and how fast will depend a LOT on if you have any plow sole and if you try to go below it,, believe me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2017 at 11:54pm
Eldon do yo still have picture
ACJake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJake Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 12:19am
I pull a 9 shank Glencoe disc chisel with twisted shanks with my two-ten around 6" deep at approx. 4 mph. In central Pennsylvania river bottom. My two-ten is weighing in around 14,500 lbs.
3 WC's, 2 WD's, 3 WD-5's, D-14 w/HenryBackhoe, D-17, 4 D-19's, 185, 190XTsIII, 200, 210, 7010, 10 L&G Allis's. Nunn Better Farms Bleed Orange!!!!!
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 11:00am
We have a 9 shank glenco and Sunflower both disk chisels. Around here they don't get put on anything less than our 8070 fwa or the 7580. Might be able to get by with less power, but it takes the weight of them to pull them correctly.
Making a living farming with and working on Allis Equipment
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2017 at 11:22am
Chisel or soil saver?
My 8030 handles a 11 shank chisel good but wouldn't dream of putting the 11 shank soil saver on it. Covered lots of acres back in the day with a 7000 and a 7 shank soil saver.
