Kohler head
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: Kohler head
    Posted: 20 Jan 2025 at 2:03pm
A small piece about .5 inches broke out of the edge where the exhaust manifold gasket goes .What have you guys used to fix the problem.It is made of Aliuenium(poor spelling)can I use like JB weld on it.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 10:31pm
JB Weld probably won’t handle the heat…
What model of Kohler are you working with?
Maybe have a blacksmith or welding shop weld it?
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 8:46am
really need to see a good picture of it, to think about 'options'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2025 at 2:20pm
Not very big piece will send picture later
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 10:34pm
flat head or overhead valve ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 9:43am
Overhead valve
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 10:51pm
What’s the model of engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 4:16pm
Kohler361
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 5:43pm
18 hp ...
do you have the service manual for it ???
I just downloaded it ,again,
 exhaust is internally tapped for 1/2" or 3/4" pipe fittings
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 7:56pm
Mine is burned out a little on the head exhaust portion the topi am using JB weld temperature is 550 so hope it holds
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 10:11pm
If you go that route you might try steelstick… it looks to be good with pressure and heat. Never tried it myself but I have used waterweld on cracked air compressor line…
https://www.acehardware.com/departments/automotive-rv-and-marine/auto-tools-and-maintenance/automotive-adhesives/8167629
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 8:59am
I think the JB weld will work. I've repaired cracked diesel blocks and never had any leaks or anything failing. Just gotta' make sure the area to be repaired is clean. Use Brakekleen to soak and get any oil or soot out of the damaged area, then mix a batch up. Give it a couple days to cure in 50 or above degrees. (if possible this time of year)
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2025 at 2:10pm
Well I did try JDWeld will see if it holds thanks for all your informstion
