AC 5015 differential and final drive
nhmath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhmath Quote  Post ReplyReply Direct Link To This Post Topic: AC 5015 differential and final drive
    Posted: 13 Jan 2025 at 3:02pm
Hi, Changed left rear axle housing oil seal . Reassembld and lowered and leak worse then before. Raised up and noticed some play in the axle. I think the bearing might be bad. Any ideas on changing the bearing without removing the complete rear housing? Any suggestions would be welcome.
I have never taken anything like this apart before.
Thank you
Neil
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2025 at 1:40pm
https://www.ebay.com/itm/256131108075- this might help, not mine - very pricey! ~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhmath Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 7:40am
Thank you. Have one already!
Pferdestärke23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pferdestärke23 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 12:04am
"Oil seal replacement rear axle(HINOMOTO E16)ENGINE:S110"
https://youtu.be/119iFCg6Oxksi=_XxN9aBey7cqjIwL
This video is about a
Hinomoto E16.
( Your Allis Chalmers 5015 is a
  Hinomoto E18 w/ orange paint. )
To remove bearing
( as is glimpsed in Vid ),
you must destroy it.
Drive a Pointed Punch
between the outside
bearing race and the
axle housing in order
to "fold it up".
Are you ready ?
Then . . .
Grit Teeth and Begin !
( Have no mercy . . . )
Edited by Pferdestärke23 - 25 Jan 2025 at 12:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nhmath Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2025 at 8:23am
Thank You.
