WC hub seal help
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: WC hub seal help
    Posted: 07 Nov 2010 at 1:39pm
Has anybody ever got these thru Napa? Is there a national part number for them ? Thanks, JM.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 3:12pm
 Agco is the only source, if your refering to the rear axle hub seal. The front seal is availble from a lot of this sites  vendors.
Edited by Gary in da UP - 07 Nov 2010 at 7:14pm
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 3:58pm
My dad had a wc  and used some stuff like pump packing.You might get the right  size from somewhere like McMaster-Carr.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 6:18pm
It would seem that if you gave NAPA the ID of the hub seal opening and the OD of seal surface on the axle,  they could supply a modern seal to replace the felt one.
Am I missing something?
This page was generated in 0.050 seconds.
