PTO generator |
Post Reply ![]() |
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Nov 2010 at 12:58pm |
Here is the generator mounted on my WF. Runs pretty smooth and has full voltage at about 3/4 throttle.
tom (OH) ![]() Silver Level ![]() Joined: 16 Jun 2010 Location: Jeromesville Points: 55 |
What size generator is that?
Tom
It's a 15KW, made by Katolight Corporation in Mankato MN. According to the rule of thumb on HP/KW that is probably as big as the WF can handle.
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2559 |
Nice. Only thing I'd add is a filler over the driveline. Piece of plywood or sheet metal so you don't slip and step down through a turning driveshaft. Now, I hope you don't need it this winter.
AaronSEIA
What is the gearbox from?
Tom
The gear box is a Federal Seal & Gear Corp. that was on when I bought it. It has a 3.25:1 ratio and at full voltage there are 2 clicks left on the throttle. Aaron, your right about safety, I will add a guard when I pull it off to paint it.
firebrick43 ![]() Orange Level ![]() Joined: 10 Dec 2009 Location: Warren County Points: 592 |
Kato makes nice generators. The big double bearings get packaged into premium sets at work. 2 or 3 MW however in size
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9523 |
I bought a brand new 40kw Katolite several years ago but have not run it yet. Had to build a trailer because I was too CHEAP to buy one.
Nice machines. I plan to power mine with my AC 180 diesel or J.D. 4050. I could use the D-17, if the load requirement is light. I figure 2 h.p./Kw |
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2135 |
Nice looking setup, I mounted mine on a small trailer. I finally got my 16kw pto wired for the house, I used the CA to power it on the maiden voyage. It will run the geo-thermal furnace, deep well and water heater, not all at once but I will be babysitting it anyway if the electric goes out. I hope I never have to use it.
Leon B
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5835 |
Yep, Kato makes nice genheads. I've got a Consolodated Diesel Electric generating plant, very, very conservatively rated 35kva, powered by a Hercules JXLD 331ci inline six... runs at 1200rpm, and man, what a sound!
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
We never sold any but I remember getting literature - don't know from whom - about trailer mounted PTO generators. We perhaps could have sold some but many used manifold valves to run their milkers with when power was out.
Good Luck!
Bill Long
Post Reply ![]() |
