Hd5/2-71 flywheel specs
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: Hd5/2-71 flywheel specs
    Posted: 08 Jan 2025 at 6:20pm
Anyone have the specs for the step between clutch surface and pressure plate mounting? Having the flywheel cut and want to make sure the flywheel is right before I install. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2025 at 1:34pm
Whoever is grinding the flywheel should have that spec . Detroit 2-71 is common to most other Detroit flywheels using the lip .
 Had mine resurfaced when I went to bi-metal disc to replace fiber clutch disc . Shop knew the specs .
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 3:56pm
Thanks, disc is hard to find. Wanted to swap also. Shop said they would find it just wanted to check it myself when done.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 10:56pm
Standard disc (fiber) is also the same as a IH L190 truck from 50's - Black Diamond Gas engine used with a 5 speed transmission
Edited by Coke-in-MN - 10 Jan 2025 at 10:57pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 8:35am
Thank you for that useful tidbit, I took a screenshot and put it in my archives. The International L-190's with which I am familiar had Red Diamond engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 5:35pm
Thanks for the info. Will check it out. Found some but all have springs in the center, original does not. Thinking I do not want springs. Already enough play in system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 11:24pm
Be sure to replace the pilot bearing in flywheel with sealed bearing and plug the oil wick hole if it has not already been done .
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2025 at 8:13pm
coke, is the wick a 1/8 or 1/4” pipe threads? Machine is 150 miles away to check. Thanks
