My new Allis Chalmers D272 hydraulic question. |
Post Reply ![]() |
John426 ![]() Silver Level ![]() Joined: 14 Aug 2012 Location: France Points: 310 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jan 2025 at 4:51am |
I have just completed my collection of small Allis Chalmers with a D272 model built in England. When restarting, the hydraulic system is very weak. I only lift 300kg. After dismantling the hydraulic pump, the relief spring is broken. After changing it, I measure a pressure of 220 bars. This pump is the same as on the C model. Same part number and spring. But I have no information on the hydraulic pressure of the D272 model. I do not have a service manual, only the parts manual. What surprises me is that the integrated cylinder of the D272 measures 76mm in diameter, or 46 cm², which with 220 bars would gives a force of 9.6 tons and provide a lifting capacity of 1.7 tons. This effort of 9.6 Tons seems very high for this small tractor and for the frame which is the stop for the cylinder. Isn't there a risk of breaking the lifting frame? Any information or experiences on this subject? ![]() ![]() Edited by John426 - 08 Jan 2025 at 4:52am |
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11753 |
Are you measuring the bore diameter or the rod diameter of the lift cylinder? I don’t think there is piston packing like on most hydraulic cylinders, so it’s the rod area that counts.
It is the bore diameter 3" . There is no rod , it is not a standard cylinder.
![]() ![]() ![]() ![]() Edited by John426 - 08 Jan 2025 at 10:42am |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
Hi John For reference only, here is a Link to a picture of the Rear of a D272: G https://www.tamarvintagetractors.co.uk/product-page/allis-chalmers-d-272 |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54109 |
220 bars converts to 3190 PSI, if I remember right, CA pump was 3500 PSI max, 4gpm flow rate. Have you checked the flow rate of the pump?
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1291 |
Just looking at the pictures it would appear that the relative lever ratios will reduce that lifting capacity by a significant amount. 300 kG may not be too far from reality.
Post Reply ![]() |
