7080 - looking for advice
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: 7080 - looking for advice
    Posted: 03 Jan 2025 at 7:48pm
Have an 81’ 7080, good shape, 4500 original hours.   Never been apart. Starting to think about rod bearings and main bearings. Pull oil samples every year, saying no metals in sample yet. I assume we should pull oil pan as a first step to check? I have little motor experience, anyone have a step by step guide? Is the Shop manual a good reference for rod bearings? Still our main workhorse gets about 120 hours per year.
Edited by dnel45 - 03 Jan 2025 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 8:08pm
If the oil samples are fine, WHY would you want to open it up to do anything ??? The oil sampling is looking at things inside without doing so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 8:12pm
Everyone says 4500-5000 hours max on 7080 rod bearings? Quite a few posts on here saying that.
Looking for opinions, I’d rather not open it up. Just wait for oil sample to show some wear?
Edited by dnel45 - 03 Jan 2025 at 8:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 8:37pm
If you use the same oil analysis service, they are like your Doctor. They will tell you when something looks questionable. Main and rod bearing life is dependent on how many gallons per hour the engine uses (load), how frequent the oil and filters are changed and the quality of the oil and lastly clean air to breathe. If you've ever been around a poor old N-6 Gleaner with worn out helical bars and the boost gauge always at 20 psi for hrs on end, the rod bearings wear out much faster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 8:45pm
That’s a nice looking tractor you have
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 9:03pm
Thanks Dr, we are very religious on all filter and oil changes. 100-150 hours max. Annual oil samples and it’s always had A/C or Agco filters and Rotella 15w-40. Will keep an eye on samples for changes.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 9:07pm
I would be more concerned about rod bolts and damper condition
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 9:32pm
Looking up info on the dampers, I’m 90% sure mine is original.   I found a thread on here discussing dampers on 8070s and replacing them with a vibratech damper for a 4-71 Detroit.   Would this be the same for the 7080?
https://www.allischalmers.com/forum/front-crank-dampener-for-a-8070_topic193124_page3.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 10:28pm
Yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 12:24am
I’m curious. 8070 and 7080 have different part numbers. What was different on the originals
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 5:51am
Shouldn't be anything different between 7080/7580/8070/4W220/N-5 and 6 /R-5 and 6. Surely from 1974 to 1985 there could have been and probably was a p/n and vender change, but they all interchange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 6:01am
A true story. I met this man in 1979 when he was about 60 years old. He was meticulous with his fleet of A-C equipment. He had a 68 or 69 series 2 D-21 that had a complete  7040 engine in it. The story goes when the D-21 was about 7 or 8 years old it had 1500 or so hours on it. In his ongoing efforts to be thee best A-C tractor caretaker that ever lived, he had his local mechanic drop the oil pan to "check" the rods and main bearings. The experienced mechanic did what was requested and reused the connecting rod bolts, of which there was an update to a better bolt at that time. The tractor ran about 20 hrs and pitched a rod right out thru the side of the block. So, the moral of the story is this......if there ain't a real good reason to be concerned, why set oneself up for a POSSIBLE failure ???  especially if you aren't skilled at doing such a thing !! If there was a real reason, that's different.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 8:50am
I have to agree with the Dr.  If it does not have a problem, why would you open it up?  Everything you are doing is keeping it healthy:  frequent oil changes, oil analyses, etc.
The engine will let you know when it has a problem.  If you are only putting on 150 hours per year, you should be good for quite a long time.
With little motor experience, I would rather let an experienced mechanic look after it should a problem arise.
Edited by DSeries4 - 04 Jan 2025 at 8:50am
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 9:38am
  Pulled rods and mains on 8050 at 6800 hrs, looked like new except for few light scratches.
   The 8050 and 7080 came with bypass filters, makes a world of difference.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 2:06pm
Agree with Doc, however IF you ever pull the pan and replace brgs if the count goes up - always use the AGCO rod bolts - they are from ARP - none better. Must follow the instruction sheet for torque procedure..
MrSnerdly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSnerdly Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 3:08pm
No advice on the bearings but that is about as sharp of a 7080 as I've ever seen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 4:22pm
If you replace mains the new uppers will have slots for piston cooling from the mains. You will loose some oil pressure. I would only replace lowers if possible. The fix from the smart people is to pull crank and drive tiny steel balls in main saddle. The block is already dilled.
Edited by SteveM C/IL - 04 Jan 2025 at 4:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 4:43pm
I would imagine that tractor still has the 4-ring pistons and piston cooling is thru the main bearings. Only the very last few months of 1981 did any 7000 series engine get the newer pistons and piston cooling design.   When "brass" starts rising in the oil samples, that would indicate rod/main bearings are getting thin.
Edited by DrAllis - 04 Jan 2025 at 4:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 7:09pm
Dr- Serial number on this 7080 is 41st from the last one made. Would this have the updated pistons?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 7:09pm
Duh, I was thinking 8070.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 7:37pm
You'd have to use the engine s/n and look on AGCO parts website to figure that out.
