Now here's a Truck!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Topic: Now here's a Truck!
    Posted: 02 Jan 2025 at 8:05pm
Good video about a '75 Hayes logging truck. What a beautiful rig!  I used to work on these many years ago installing the logging rigs on the trucks. The Hayes was always a favorite.  They were built in Vancouver BC.. I worked for a branch of the company here in Alberta.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2025 at 8:52pm
Enjoyed the video. Thanks for sharing.
So I’ll take a stab about truck’s approximate GVWR ~ 144,000 lbs ?
2-12k steer = 24k,
2-20k drives = 40k,
4-20k trailer = 80k.
Edited by AC7060IL - 02 Jan 2025 at 8:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 4:34am
Most likely closer to 160K, 44-46,000 drives, 14-18,000 steers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 2:55pm
Do both front sets of wheels turn ? Never seen anything like that . Thanks for posting
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 3:58pm
Twin Steer they both Steer.  Generally the Rear axle has a Parasitic Hydraulically Connected gear, set at a ratio to not over steer the lead axle.
Kenworth has added this to their line up, so a Mixer truck can go 12 yards capacity without a trailing axle.
Edited by DMiller - 05 Jan 2025 at 4:04pm
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 5:27pm
Tandem steer. Tri drive. We have sold a bunch of these at the IH dealership where I work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 5:32pm
In Ontario this setup is good for 92,000 lbs gvw. They drive like a caddy. I pick them up at London Equipment and deliver to various locations around the province. Handle well and go around the roundabouts easy. 😀😀  This is International truck.
Edited by Ed (Ont) - 05 Jan 2025 at 5:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 7:01pm
All major builders have them now. Axle spreads for Bridge Formula.
Edited by DMiller - 07 Jan 2025 at 11:23am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 7:11pm
When I worked at CEI a couple trucks were built on Freightliner chassis. Twin steer under a cabover day cab. 30ft box. Twin screw and a tag. Neat looking truck.
Edited by plummerscarin - 05 Jan 2025 at 7:12pm
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2025 at 2:55pm
50 years ago, I still can remember talking with a trucker who had that setup under an Autocar. He said it work great. He said you couldn't tell it from a single front axle.
This page was generated in 0.250 seconds.
