Info on a blue one...
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: Info on a blue one...
    Posted: 28 Dec 2024 at 10:14am
.. is there a sight for older Ford tractors as in this one ?
We have a 3400 in the shop that will not raise the 3 point at times.
New pump, reworked top plate, cleaned strainer, changed oil... nothing now.....
Edited by tbran - 28 Dec 2024 at 10:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 12:22pm
i have had limited success with these guys...
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 12:56pm
I have no idea this is the problem:
youtube
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 8:52pm
Watch YouTube videos by Bundy Bears on Ferguson tractors. The Fords are copies of Ferguson 3pt system.
I had the clip that holds the pump control linkage fall off (water in the sump froze).
You may have the draft circuit set wrong or the draft spring/sensor faulty.
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 4:59am
Try Facebook. Many old Ford tractor sights there and you get answers from all over the world.
I signed off and quit using Yesterday's Tractor. Too many ignorant grumpy old men there.
God forbid you have a light that is not factory original, or convert to 12 volt or electronic ignition. You will get belittled and flat out told you are an idiot.
So I'll just leave them to live in their miserable little disgruntled lives.
ekjdm14 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 8:27am
I think the AI bots are listening in, "Alizawalker" in particular got the wrong kind of blue one LOL
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 10:15am
is it an industrial? or a compact ?  i dont see a 3400 on tractor data
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 12:17pm
Industrial unit - thanks...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 5:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 6:59pm
was the lift cover removed ?  is their a o ring that is missing   does this one have a pump that comes out the right side behind the running board ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 8:01am
Yes, cover removed and ran with it off to test. We have nothing at 3 point as to trying to lift. It lifted fine after pump replacement. Then quit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 9:25am
so, is the pump putting out oil, just not going thru the plate/ valve ?
Pump is as you say left rear of engine.
Bleed screw is a 3/8" pipe plug - usually socket head - on the side of the pump. Run the engine at low idle and unscrew just enough to make it dribble oil.
When the bubbles are gone and you get a steady flow of oil retighten.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2025 at 3:06pm
Yes pump is pumping - may be sucking air - really a rube-goldberg set up. But then I am used to simple....
