8070 won't move.
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Topic: 8070 won't move.
    Posted: 27 Dec 2024 at 7:21pm
8070 with power director suddenly stopped moving. Power steering, hydraulics, and PTO still work. Trans light goes out like normal. I haven't checked the pressure with a guage yet. Before this happened it felt like it wanted to start out in high range, then when clutch pedal was nearly released it would downshift. I'm thinking it's gonna need a split, just wondering what the problem may be. Need a little help with diagnosis before I make myself a lot of unnecessary work. TIA.
WD,D15,190XT,7000,8010x2,7060,8070
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 8:33pm
Sometimes, the tie strap that holds the range cable in its notch under the floor board breaks. If that happens, you won't be able to put it in high or low range. Also, with the engine running and the clutch pedal up,can you put it any gear without grinding?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 10:55pm
Good call Lynn, I fixed my neighbors 8070. Criss crossed tie wraps broke after 40 years. 2 new ones resolved the issue. Pull the seat, access panel and there is the location of the culprit. At least on my neighbors tractor.
Edited by AC720Man - 27 Dec 2024 at 10:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 11:20pm
        Clutch pedal up and engine running- grinds when trying to put in any gear. I can "hear" the power director shift from low to high, but no movement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 6:25am
If the range shift /park lever cable or cable clamp is the problem, the Park lever will feel terribly funny with little drag on it when shifting..
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 8:53am
Question, when you have the unit running, can you shift gears w/o grinding ? IF so - the issues are hyd or mechanical in the power director mechanical rotating unit.
Edited by tbran - 28 Dec 2024 at 10:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 10:24am
With the engine running, clutch pedal up,do you get the grinding noise when shifting the range lever into either low or high?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 6:51pm
i'll check the range lever tomorrow and report back. Worked on the grand sons snowmobile most of the day today, now the snow is mostly gone, oh well...
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 10:21pm
I drove an 8070 home in 6th gear low range once because the tie strap on the top end of the cable just under the side console broke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 8:53pm
        No grinding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 9:47pm
I don't think that it's getting into either high or low range. Therefore it won't move. With a little help,you may be able to watch from outside while someone else shifts the range lever in the cab. The outer shell of the cable needs to stay still and not move while shifting. Only the inner part of the cable moves. The problem is probably under the cab,but it's easier to look at the upper part in the cab first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 10:35pm
Let's try a new shifting test. Have the engine running at 1000 RPM and your foot OFF the clutch pedal. Jam the 5-speed transmission into 1st gear.  Then, jam the range transmission into HIGH range. Then, shift the range lever into neutral and wait 5 seconds and jam it into LOW range. Do all this shifting with your foot off the clutch pedal!! If you feel the tractor trying to move the least little bit, then lets flip the Power Director lever/switch into HIGH range and see what happens while everything is still in gear. If the tractor still doesn't move but feels like it is trying to move, the splines inside the Power Director clutch housing are gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 10:46pm
        High low lever moves the arm on top of transmission. I'll try the Doctors test tomorrow,but it's looking like the problem is the power director.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 12:57pm
I worked on a 7060 once that had sheared the splines in the large coupler that connects the transmission to the rear end. Very odd failure. However, it made a very obvious, ratcheting noise, when in gear and not moving. I replaced the coupler and the input shaft to the rear end on that one. When the splines strip in the power director housing, you won't hear it. Also, not a common failure, but I've seen it a few times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 9:03pm
    Doesn't feel like it wants to move. Transmission grinds into gear slightly, range doesn't grind. That tells me transmission isn't turning, correct? Power Director splines must be gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 9:13pm
If it is that way in both low and high on the Power Director switch on the steering column, I would say yes.  You could try running 5th gear using the clutch to nicely get it in gear and then grind in the range trans into LOW and see if it makes sense.
Edited by DrAllis - 31 Dec 2024 at 10:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 10:09pm
  Tried every combination with the low and high  range, etc., still no go. I didn't check pressure at the port yet, (my guage is broke) do I need to check that or am just putting off the split job?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 10:23pm
If you can "hear" the Power Director clutches shifting and the red light blinks at you, I think your pressures are fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 12:46am
As the first step in splitting,drain trans and pull off the bottom plate where the screen is.....see how much metal is laying there. That would help confirm a teardown.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 6:47am
Actually, if you dropped the sump directly under the Power Director clutch, and reached up inside with a bar, you should not be able to rotate the P.D. clutch if the splines are good. Good splines would rotate the engine. Bad splines will spin the clutch assembly pretty easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 11:57am
I worked on an 8030 once that wouldn't move. It had a differential problem and would only move with the diff lock applied. I think that it dropped the spiders pin. I wouldn't suspect any problem there on an 8070. I believe that the power director splines are gone on yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 2:27pm
I appreciate all the help from everyone and I'll let you know what I find when I tear into it. Happy New Year!
js case View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote js case Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 7:42pm
I might suggest that the low range hollow shaft has snapped .  This was a problem for the high HP AC tractors with the Power director clutch.   I had seen several times when the shaft would snap on a downshift.  Customer tirning into field slowing down.  Pops the PD to low and tractor rolls into field and then will stop moving.  Also several pulling into shed the same way.  If this is the problem , the shaft can be cut out and then new one installed after some grinding.  The Shaft on the 7580 { if I remember correctly } already comes with the collar shaved off so the shaft can just be slipped into the front without taking the transmission apart.  I wouldd check all the previous suggestions but if it comes down to a tear down I would check this shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2025 at 8:33pm
Haven't had time to work on it yet, always seems to be something else that needs repair. I'll let you know what I find. Thanks for your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2025 at 8:29pm
I finally got the 8070 tore apart. Main shaft snapped at oil holes. Looks like kind of a poor design. Anybody know where I can find one? Also need part number 70272069 which is called the rear oiler. Shaft part number is 70262008, did not called dealer yet.  TIA.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 9:41am
   I have one, was keeping it for a spare for my puller,  now thinking I should go billet, four smaller holes would be stronger then two big ones ??
   Looks spendyOuch   Not far from you, PM me your phone no.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 2:26pm
Well, rare failure - it is used on 7580.... an all - plus a lot of 1000 + or -  HP pullers..
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2025 at 6:34am
   Sent you a PM, call me at your convenience.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2025 at 12:59pm
Spendy would have another 0 at the end. I spent near that on an equally short splined on one end shaft for the drive on a black corn head. It's not hardened or anything.
