Let's see your Gleaner |
| Author | ||
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Topic: Let's see your GleanerPosted: 25 Dec 2024 at 1:22pm |
SteveM (IL) had sent me this photo of his Gleaner F2, along with his other tractor photos to be posted on the forum. So,,, I figured why not let Steve begin a "lets see your gleaner." post. ![]() Edited by AC7060IL - 26 Dec 2024 at 9:56am |
| Sponsored Links | ||
cjarosz
Joined: 22 Nov 2009 Location: Columbus, IN Points: 107 |
Posted: 25 Dec 2024 at 2:01pm |
![]() ![]() ![]() Few years ago vs now |
plummerscarin
Posted: 25 Dec 2024 at 7:54pm |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 25 Dec 2024 at 8:40pm |
Edited by Lynn Marshall - 02 Jan 2025 at 12:33pm |
Lynn Marshall
Posted: 25 Dec 2024 at 8:41pm |
Edited by Lynn Marshall - 02 Jan 2025 at 12:34pm |
DrAllis
Posted: 25 Dec 2024 at 8:59pm |
Leaner, Meaner and a Gleaner !!
tractorboy
Joined: 03 Oct 2009 Location: southern Va Points: 480 |
Posted: 25 Dec 2024 at 9:04pm |
Nice !!! Never been in a combine ............ on my bucket list
Northern Hoser
Posted: 26 Dec 2024 at 10:19am |
![]() Got warm enough to clean them up... |
NEVER green
Posted: 26 Dec 2024 at 10:26am |
Favorite part of farming, dont miss cows one bit.
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
jvin248
Posted: 26 Dec 2024 at 6:17pm |
That machine looks like it came from the future! https://www.onallcylinders.com/wp-content/uploads/2015/07/back-to-the-future-delorean.jpg ![]() |
AC7060IL
Posted: 26 Dec 2024 at 7:59pm |
SteveM C/IL, nice F2. Does it have a G/M/L right side grain tank fabricated into it?
Edited by AC7060IL - 26 Dec 2024 at 8:01pm |
ToddnwIl
Posted: 26 Dec 2024 at 8:24pm |
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 634 |
Posted: 26 Dec 2024 at 8:36pm |
l3 & C
Edited by SteveMaskey(MO) - 26 Dec 2024 at 8:38pm |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 26 Dec 2024 at 9:17pm |
I don't know the back story. Was this way when I bought it. It took a while before I realized it was extended. Whoever did it did a pretty decent job. I think they did something different with the bin loader elevator side as well. My elevator is inside the bin and I think OEM had it on the outside. Not sure on that one. Had trouble with left side final axle nut coming loose as Mack said would happen when overloaded LOL. After looking at it I think the bin extension is moved to the outside of elevator VS inside of elevator.
Edited by SteveM C/IL - 26 Dec 2024 at 9:22pm |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 725 |
Posted: 26 Dec 2024 at 9:42pm |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
AC7040
Posted: 27 Dec 2024 at 6:58am |
![]() At Rantol last year. Just got her unloaded. Was a lot of fun using her to take some corn off. |
1953-WD45, 1949-G, 1950s Snap-Coupler All-Crop Drill, 1956 Roto-Baler, 1945 All Crop 60, Snap Coupler Subsoiler, Plow, Gleaner F, 505 wagon
wjohn
Posted: 27 Dec 2024 at 8:27am |
I love that old open station E! I would have liked to find an E/K but found my CII just 6 miles down the road instead.
AC7060IL
Posted: 27 Dec 2024 at 8:44am |
Edited by AC7060IL - 27 Dec 2024 at 8:49am |
SteveM C/IL
Posted: 27 Dec 2024 at 10:16am |
I have 2 sprocket setups for clean grain. The factory speedup for corn and a custom slow down speed for soys. Just swap out driven sprocket on auger and use a longer chain. Do not have a capacity problem
AC7060IL
Posted: 27 Dec 2024 at 11:16am |
Awesome. So I gotta ask,,,what’s your F2’s grain tank bushel capacity? And how did you overcome its Left final drive nut issue? Thinking about it operating in a loaded grain tank state, it’s right final drive would be more weighted to ground. If that’s true, then that means trans’ differential directed more torque to lighter left final drive?
Lynn Marshall
Posted: 27 Dec 2024 at 2:14pm |
Not exactly a Gleaner.
SteveM C/IL
Posted: 27 Dec 2024 at 2:26pm |
It seems to be around 100bu less than 18% corn. The finals just have a nut setting bearing clearance. It does not draw against a spacer or anything so the left side tries to turn the nut loose just from direction of rotation and it shears the flimsy pin in the castle nut. Don't remember if it's a cotter or roll pin. Mack said to drill hole out and put a 1/4 inch? roll pin in it. I cleaned it well and used Loctite stud and bearing with a new pin and so far so good. It's been several years. I pulled it apart a couple years ago because it was leaking out the seal and that's what it did when it first sheared and loosened up. Nut was tight on threads so I put it back together. Don't know why it leaked but it quit.
Edited by SteveM C/IL - 27 Dec 2024 at 2:31pm |
VAfarmboy
Posted: 01 Jan 2025 at 10:19pm |
1971 Gleaner K
