Early B spline nut size.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Topic: Early B spline nut size.
    Posted: 23 Dec 2024 at 6:39am
One of the details still needed to be squared away to be able to drive the rusty redneck B off the trailer is to secure the right rear wheel back on. I'm missing the large nut that holds the splined joint together, am I correct in my measurement that it's 1 1/2"-12 fine thread?
Thanks, Dan.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 7:46am
YES .................in the US... ANY BOLT  bigger than 1-1/8 inch has a 12 thread per inch STANDARD Fine Thread..
just for information sake.. If you were working on a large steam turbine or 5000 HP electric motor that has   2 or 3 or 4 inch diameter bolts... they PROBABLY have 12 threads per inch..... Thats a STANDARD.. Makes it easier for Machinist to repair or make a shaft in a lathe since they are all the SAME..
Edited by steve(ill) - 23 Dec 2024 at 7:59am
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 9:06am
Too bad you're across the big pond, I have a lot of the parts that you've needed to resurrect the B you're working on. Shipping out of the US had always proved too much of a PIA to make it worth the trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 9:24am
the actual NUT was a SPECIAL PART made by ALLIS.......... but you can buy a HEX NUT that will fit.... Should be available at local Fastener Shop.....i have wondered why ALLIS didnt just buy HEX NUTS for the axle ?
Edited by steve(ill) - 23 Dec 2024 at 9:26am
ORBill View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ORBill Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 11:44am
Dan
Your resourcefulness in getting this old B running is amazing, but it’s hard for a lot of us to watch your struggles knowing we have the parts you need. You never know how parts can make it across the pond. I took a CA gas tank in my suitcase to Australia a couple of years ago. That makes small things like nuts and distributors easy, just have to keep it under 50 pounds!
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 4:00pm
Yep, wish I were over there for more than just the parts availability. This country is a mess!
Steve, thanks for the confirmation. I'm imagining Allis used the special nut maybe for slightly wider flats for the huge torque? Either way, should be able to get something locally that will suffice.
Bill, I'm sure there's parts available over here too if I really wanted to pay the money for them. My struggles mainly are the result of my tight wallet & a desire to see a tractor that would otherwise be headed to scrap work again. (remember, the tins are very rotten & a good deal of heavy corrosion even to the iron parts, non-original rear wheels also rotten. TBH I feel like this was a yard scraper or otherwise working in slurry for a good deal of it's life)
Rest assured though none of the hackery is irreversible & if I do want to make it right in future it's a simple case of unbolting my hacks and installing correct parts. The old girl is growing on me & even if I don't take her to the next level it ought to be a lot easier to find someone to take her on if I can demonstrate that the bones of the machine are sound. Honestly though, I am feeling like she may stick around a while Smile
Edited by ekjdm14 - 23 Dec 2024 at 4:04pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 4:13pm
Personally i  like to read your posts about the home made rocker shaft, Ford Distributor and who knows what for water pump... Everyone needs a little smile time in their life.. I get mine from YOU.... I have done a lot of MODS in my life time, but never to this extent.. I REALLY get a kick out of your  resourcefullness !!  Thumbs Up
--- are you any kin to a guy named MacGyver ??  Wink
Edited by steve(ill) - 23 Dec 2024 at 4:14pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2024 at 6:43am
OEM B axle nut
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2024 at 10:27am
No relation, shockingly enough
The more I think on it the more likely I'll just modify the Perkins WP internals when I'm at the point of running it longer than thermosiphon can cope with. Be a while yet though.
Wishing a merry Christmas to you all & a new year filled with Allis goodies galore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2024 at 10:32am
OEM B axle nut
That's the beastie right there sir. All I can think is they wanted a larger surface area for torque application than a 6 point would have provided. I'm sure a Fein 1" 110v impact will get me close enough though as long as the socket holds up to the abuse!
