Older Gleaner Finger Guide Differences
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Older Gleaner Finger Guide Differences
    Posted: 21 Dec 2024 at 7:14pm
My CII has what I suspect are aftermarket guides on the pickup and feeder beater fingers, as they don't match the AGCO parts book. Most of the ones in my machine are gone from rats or are too brittle for the rats to be interested in them, so I need to replace all of them.
Has anyone had experience with both styles? Aftermarket would of course be cheaper and the guide and retainer are all combined, but if they're junk, I'll spend the money on the parts for the AGCO style.
Parts book:
My combine:
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 8:19pm
I always used the ones like you pictured.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 8:33pm
You haven't been able to buy the 2 piece for 40 years or more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 10:38pm
That's interesting to hear. All of the old style parts listed in the C/CII catalog show current pricing and stock available, including the metal retainers. Sounds like I can save some money and use the one piece poly ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 10:40pm
My F2 has the plastic ones in platform conveyor. They are kind of fragile. You can squish the hole apart with too much tightening. I use Loctite on threads and snug firmly. I just replaced some this fall. My help was running machine and I was standing on end as she finished the through. SOMETHING DON'T SOUND RIGHT!!! The help never knows something is wrong by the sound. Let's call it inexperience. 2 completely missing on platform with fingers rattling! I usually rub the clutch and roll machine over while looking for guide trouble first of each day but I wasn't driving and can't remember everything to tell everybody.
Plastic ones ain't exactly cheap.
Edited by SteveM C/IL - 21 Dec 2024 at 10:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2024 at 6:44am
I'll have to go look at my NOS Gleaner parts. I know there were some of them there at one time. It may be the end of the week before I get out to the barn to look.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2024 at 7:53am
I thought the rubberish ones used a shoulder bolt to prevent overtightening
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2024 at 8:00am
They used both the self tapping and shoulder bolt design. Between the fingers and guides for the header and feeder beater,there were more design changes than Carters got pills.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2024 at 9:23am
That explains it! I thought they were shoulder bolts but these are not. Must have been shoulder bolts on the A2. I've not touched the F2 conveyor as I had dealer put new ones in when I bought it.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 1:40pm
I've got a 1973 M with self tapping screws on the feeder beater and shoulder bolts on the header auger...as was previously stated, they did running changes. It was confusing to me first time I changed some guides.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 3:41pm
Like SteveM (cIL) stated earlier, the plastic guides often break & probably get ingested by machine? If you quickly catch a missing guide, their replacement is minimal effort. Let it go too long & you could be refabing the mounting area that becomes bent-in from constant bashing.
Maybe look for the cast metal replacement guides offered by AGCO? They are pricier, louder during operation, but will last a long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 8:24pm
Ah, that explains a few of the tiny shoulder bolts I saw laying around the shop floor at the place I bought the combine from. If I'd known what they were the seller would've happily let me take them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 8:28pm
I have one hole completely missing the finger, guide, and hardware that looks like it will need to be straightened so that's probably what happened to it. Thanks for solving that mystery.
I did see the cast or forged guides and yes they are pricey. I was planning on skipping out on them since they probably wear on the fingers much more than the plastic? I did see somewhere in my research that forged guides were part of the corn/soybean special package, and were recommended with corn which would make sense. I don't have any irrigation on my land so I won't have to worry about corn, at least - just wheat, soybeans, and milo.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 9:13pm
Were the fiber pins intended for the cast bushing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2024 at 10:51am
My A2 had plastic in both conveyor and beater. Did about 40A corn per year for 19yrs without much trouble. Just had to keep eye on them. My F2 has steel guides in beater with larger fingers. It is a corn/soy special.  I think it's 5/8 VS 1/2. Has around 4000 engine hours and has done the same 40A corn per year for 24 yrs and while there is wear on the fingers and steel guides it's not that much. The tips are worn worse that the shanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2024 at 7:03pm
Thanks - that's good to know that the metal guides don't wear the fingers that much. Most of my fingers will be reusable so I'll look at whatever guide options are available for the smaller diameter fingers that my combine has.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 10:12pm
John if you look at the pair of L3's in the Gleaner post,the one on the right shows the heavy fingers and guides in the feeder beater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 10:22pm
The 5/8th's fingers and forged steel guides were the result of too many problems in corn country. Also the no grease poly sleeves inside the drum was also a corn thing.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 8:07am
Just a note, nothing to do with finger guides, but to those running the older headers that do not have the double wall center sections on the auger- I would weld angle iron pieces across the center from side to side. Down thru the years the inside is rusting and thinning. A finger that bends and pokes holes in the header auger will cause a failure with the auger being cut in half at the perforations. There are no more augers for replacement and if one finds a good used one - it is a multiday task to remove and replace two augers. 6 or 8 cross angle iron pieces that go between the fingers will  strengthen the auger satisfactorily.
