Allis-Chalmers HD16DC Hydraulic Issue Help
DIY-Mechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIY-Mechanic Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers HD16DC Hydraulic Issue Help
    Posted: 21 Dec 2024 at 4:43pm
Gday Guys first time posting, from Australia in need of help, I have a hd16dc with s/n 6172 and engine s/n 16-05291, First problem I have is no clutch or brake power on left side, problem two is the oil in the torque converter tank is milky but not watery more of a condensation build up I think,
But the oil in the tank at the front near bottom of radiator is good, are these two tanks connected? We changed the oils when we got the machine, which didn't fix the problem, plus now the blade and ripper don't lift, no Hydraulic functions, air in the system maybe, if so how to bleed, appreciate any help, don't know much about these machines.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 9:23pm
Welcome to the forum! I recommend that you post your questions in the section called "Construction and other Equipment" as you will be more likely to get responses. This heading you're in is mostly for farm equipment.
Take care and Merry Christmas!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 9:55pm
you need hydraulic PRESSURE to work the steering clutch and brake... Check filter / suction screen, dirty oil , sucking air...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIY-Mechanic Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 10:36pm
Thanks Guys, have moved the post to the construction group.
