Remove spool valve, AC-185
Allis_Cooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Topic: Remove spool valve, AC-185
    Posted: 21 Dec 2024 at 10:31am
Just an update. After getting advice on this forum I removed the spool valve for the main lift on my AC-185. I now see that my main leak was coming from the fact that the rear spool valve cover had one of the ear broken off on it so that it wasn't tight enough and fluid was leaking out of the o-ring on the back.
Does anyone know where one might get one or two of these spool valve covers?
I've tried AllState and Bowman's but have not heard back from them.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 11:27am
70243653 available at any Agco dealer - it is a Husco valve used on many OEM hyd.
i.e.Gehl older skid steers.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2024 at 8:17pm
We need to talk. I think I have two of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2024 at 11:10am
I'll buy both from you if you do. The Agco one in like $54! And then they will want a ridiculous shipping charge.
Doug Barlow:   doug.barlow@protonmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 8:19pm
Edited by Unit3 - 26 Dec 2024 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 7:34am
Thanks, those appear to be the correct caps. The main hole opening is about 7/8 " diameter and the two screw holes roughly 1.5" to 1 5/8 " apart. So how can I get them from you?
