M & W oil pan
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Topic: M & W oil pan
    Posted: 20 Dec 2024 at 9:39pm
looking for an M&W oil pan for a 220.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 9:52pm
Doubt there were any made for AC
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 9:04am
   None that I know of.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 8:07pm
artcle on m&w oil pans in the new heritage iron magazine this week
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 7:56pm
I read the article in HI and thought i would ask. I dont remember seeing any back in the day.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 5:46pm
Does anyone have an IH M&W oil pan?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 5:54am
They are out there but are very speedy! Like $1500. If I had one I don't know if I would keep it for the cool or sell it for the easy cash?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2024 at 10:38pm
I have seen them go far North of that number. A good friend of mine has a gold demonstrator that he would love to find one for it.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 10:47am
im pretty sure one sold on the Facebook IH auction page this fall for $8000-9000
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 7:15pm
What is so special about them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 10:39pm
They hold more oil and look COOL !!    M & W made turbocharger kits for 4010/20's and 806/856's and they recommended this aluminum oil pan to keep the engine oil cooler as it had cooling fins made into its sides and held another gallon or more of oil.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 2:06pm
Here’s a link to a 2022 posting on the red power forum about it. Posting includes a few photos of it & their realized auction prices then.
Here are a few photos of a JD4020 M&W oil pan.  Checkout how it is dimpled on the inside.
Edited by AC7060IL - 30 Dec 2024 at 2:42pm
Michagman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michagman Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 4:58pm
That does look cool!  I wonder how much it really does to keep the oil cooler.  If those fins work, it seems like they could have been formed into the sheet metal pans too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 6:12pm
Copper beats aluminum for fluid heat dispersion. Hence, the better radiators usually contain copper cores. But the economics usually favor aluminum which disperses fluid heat far more quicker than most mild steel or cast metals.
M&W’s aluminum oil pan was an economical cooling option for most fueled-up 1960s turbocharged diesel tractors. None of which probably contained intercooler/larger radiator that helped confront their inherent excess heat created by turbocharger’s intake air compressor turbine coupled with increased fueling.
AC did a good job offering various higher hp diesel engines equipped with piston cooling, oil coolers, & intercooler systems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 7:16pm
IF, someone wanted to make a few for the 426’s, I would think they would sell out fast!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 9:01am
  What????    No baffles??    I guess it would be hard to make cast ones, could bolt some thin steel ones in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 10:48am
  Kinda ironic but over on Pull Off .com  a guy just yesterday offered to recast the pans, possibly other makes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 2:07pm
Here you go…. For those interested, this is a link to the pulloff.com forum’s that I believe NEVER green has mentioned?http://www.pulloff.com/phorum/read.php?2,342865,342865#msg-342865
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 6:27pm
I wonder if Luke Roseboom is paying attention
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2025 at 11:09am
It probably helped.  Back in the day my dad had a 4230 that a previous owner had installed an M&W Turbo kit on but they didn't install the aluminum oil pan. I guess they figured that since the oil pan on the 4430 with a factory turbo was the same size they didn't need it, but the radiator on that 4230 was so small that on a hot day the heat gauge would creep over to the edge of the red pulling a four bottom plow that we used to pull with a 3020 before we got it.
Edited by VAfarmboy - 02 Jan 2025 at 11:10am
