Allis wd45 distributor gasket none like mine |
Post Reply ![]() |
Orangeypeach99 ![]() Bronze Level ![]() ![]() Joined: 15 Jun 2024 Location: New mexico Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Dec 2024 at 6:26pm |
Mine has the same holes as all the other ones I've found online but my distributor has a guide stud on it any help to find gasket?
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2186 |
If I understand correctly you just need an additional hole in the gaskets you're seeing online in order for it to work in your setup?
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2569 |
Don't think I've ever seen a gov housing with a locate dowel. Either way, just punch the extra hole you need in the gasket and bolt it on. AaronSEIA
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21747 |
If the governor housing (NOT the distributer !!) has a small line-up dowel, that is for the timing gears backlash !! Each engine may be a little different and yes, the gasket, which has no holes, gets that hole punched in it.
I bought a set of these years ago and I use them all the time:
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4982 |
X 2 wjohn!
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5898 |
X3 wjohn I drilled a bunch of various sized holes part way in to the side of a piece of 2 X 3 and mounted it to the wall. Now my punches are always within reach' G |
Post Reply ![]() |
