Wd/wd45 cylinder stops?
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd/wd45 cylinder stops?
    Posted: 20 Dec 2024 at 8:07am
Has anyone tried using cylinder stops on the rear lift arms when working with a loader? I'd like to hang a counter weight in the 3 point for moving snow. I do not want to add a seperate spool for the loader because I would prefer it to remain factory. Any ideas?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 9:53am
Normal stops won't do well with the way the cyls connect to the arm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 10:20am
If someone could post a picture of the row-crop front mount cultivator, there was a lift arm stop with the rear tire track scratcher. Put one on each side and drill a hole to prevent the stop from sliding from your extra heavy weight. This will work and do what you want it to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 11:49am
Mines disassembled hanging on the barn wall but the left lift cyl gets un pinned and swung fwd to raise the front section. I think the stop rod was pinned in lift arm and slid through an angle iron on back side of fwd cyl bracket so I'm not sure what you are saying will work? Been many years since I installed it so memory could be off a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 11:59am
You are correct that the left cylinder gets swung forward. I'm thinking a similar design, but installing a long grade eight bolt on the rear pin location and anchoring the new stop(s) there and go forward to the side frame bracket, similar to, but not quite identical to the cultivator set-up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 12:09pm
That would probably work....
