Air ride seat
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: Air ride seat
    Posted: 18 Dec 2024 at 10:57am
Anyone put an air ride Gleaner seat in an 8000? My 97 R62 has a Grammer air ride seat. I'd think there would be something in salvage yards for considerly less than new from vendors. Thoughts?
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 12:17am
Hmm ,. I was hoping someone would answer this,i have a spare seat out of a r-72 I’d like to use in a 7080🤔
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 6:51am
Maybe instead of looking for an air ride seat, it would be better to do a better job of properly preparing smoother ground prior to planting.  Slowing down to a reasonable speed could also help. I see many these days travelling across a field faster than a CA will go on the road.
Edited by PaulB - 20 Dec 2024 at 9:33am
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 11:04am
I'm sure you could take a used base and make it work, but for what i've been quoted from equipment salvage yards it wasn't much cheaper than new. And going new means no worn out bushings or linkage in the base. I put in an air-ride base and swivel kit from K&M and re-used my factory seat that i had reupholstered. Turned out pretty nice, although the factory seat lacks in comfort and support compared to a newer seat. I'll probably end up removing the original seat at some point and going with a newer one. The seat in my R52 is considerably more comfortable.
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 12:03pm
Paul,you know nothing about that which you speak. You read alot into things.
This page was generated in 0.041 seconds.
