F3 variable speed header drive
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: F3 variable speed header drive
    Posted: 15 Dec 2024 at 8:39am
The variable speed header drive sheave is stuck in the slow position, out against the stop bolt heads on the F3. What is the trick to getting it free, please? My mechanic did this a few years ago but I don't know how he did it. I'm preparing it for sale and hope to have this taken care of.
If anyone needs a good F3 with heads I will be listing it on FB Marketplace soon.
Part time farming with a 1980 7060 and 1984 F3 hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 12:48pm
Don't know how it could be stuck. Hyd hose connected and pressure applied while running should move it. It's just a piston.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 12:50pm
I'll give it a whack, maybe that's all it needs. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 3:33pm
To be stuck in "SLOW" speed, the belt is at the top of the lower sheaves, not down inside the sheaves. Meaning the sheaves are not spread apart, they are already squeezed together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 4:01pm
I thought against the bolt heads or stops is set at slowest speed. I think it's stuck, the speed control rocker switch won't make it change speeds. I guess the switch could be bad. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 4:35pm
Those header drives usually require the corn head to be hooked up and running at full throttle to get them to slow down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2024 at 8:44am
I couldn't get it to move at all this fall in corn, just ran it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2024 at 9:21am
Against bolt heads on drive pulley will slowest speed. Hast to be running to move especially if speeding up. Sounds like you electric over hydraulic has a problem. Can't imagine it being able to stick unless something wrong in lower pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2024 at 9:47am
Seems like the upper sheaves aren't getting the oil released to be able to slow down. I'm thinking electrical, but could be the hyd valve itself. Unplug the hose on the upper sheaves. Then. remove the hose coupler and run the machine with the header running. Oil should squirt out and the sheaves will then slow down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2024 at 10:02am
Thank you guys. I will experiment and see what happens. I really appreciate the help!
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2024 at 10:28am
On my L3 the solenoid coils are bad for getting corroded and not grounding. It could be just that simple. We take a little wire brush on a dremel tool and clean the cup and groundind ring on the coil
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2024 at 8:34pm
Thanks everyone, I appreciate all of your help. I tried it again today it worked fine. I assume I had tried it with the header drive off before. Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 12:06pm
That would do it. Has to be turning to operate.
This page was generated in 0.067 seconds.
