Wtb series 417 loader axel mounting brackets
JoshDay94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Topic: Wtb series 417 loader axel mounting brackets
    Posted: 14 Dec 2024 at 4:50am
Hello. Would anyone have a set of the angle iron axle brackets from a 400 or 500 series loader to mount to the D17 rear axels they would part with? I have a set from mine for a D14/15 axle I would swap with if interested.
Or option 2. Would anyone be willing to lend me a set so I could get made at a machine shop based off an original set? I'd pay shipping to and back to you if at all possible.
Or option 3. If you'd be interested in taking a set to your local metal fab shop and having them make a set would work too, id glady pay for your time spent.
Any ideas or help would be greatly appreciated.
Edited by JoshDay94 - 14 Dec 2024 at 5:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 7:20am
I'd suggest you first order the official A-C axle loader U-bolts and nuts from an AGCO dealership. Then buy some angle iron the exact same width and thickness as the loader frame currently is. Cut angle iron into 4 pieces of measured lengths. You could use scrap lengths of 2 x 4 wood to determine your lengths. Drill holes for the U bolts and lightly clamp to the axle. C-clamp the horizontal angle irons to the loader frame and mark where the holes need to be drilled and drill them. Bolt the horizontal angle irons to the loader frame, swing the axle angle iron into place and clamp the angle irons together tight and (for me) tack weld them together, remove and weld really good on a welding table. If you clamp them together really well and two people gently remove them from the tractor, take them to a welder to have them fused together.
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 9:00am
Josh call me. Will get you pics of what I got on a d17 for brackets. 402-469-1738
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 9:59am
You are about 18 months too late. Back then I got a 417 loaded to put on my D15II and the only rear brackets I could find the person wanted more for the 2 rear brackets and shipping that I paid for the complete hardly used loader. I ended up cutting the D17 brackets up to build the D15 brackets. The D17 brackets are nothing more than bent angle iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshDay94 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 10:20am
Thanks for the ideas, but I don't have access to a welder or shop to build them myself due to family fall out or I would.
Thats why I was hoping to find a set here or work with someone to have a fab shop build a set for me.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 11:52am
Josh... PM me your contact info.. Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 7:37pm
I got them. Just have to call.
