Final drive housing similarities. D17
Dragfluid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dragfluid Quote  Post ReplyReply Direct Link To This Post Topic: Final drive housing similarities. D17
    Posted: 12 Dec 2024 at 12:22pm
Series III D17. One of the final drive housings (cast part) needs to be replace, once I start working on it. There's a guy that has a crapload of WD and WD45 parts that he's trying to get cleared out because he's moving. (in Elk River, Mn)
Is the '45 housing the same? I can swap the gears if they're different.
Thanks!
Series III D-17
Many others in my life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 12:29pm
Not the same. What part are you wanting to change?? The tube?? or the bull gear housing ??  All the gears inside are different tahn a WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dragfluid Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 1:58pm
Both the bull gear housing and the tube. Both are broken at the flanges. I had welded it up when it happened many moons ago, but I'd like to replace them with non molested parts.
Thanks! Guess I need to search some more.
Series III D-17
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 2:20pm
Series 3 and 4 should be the same parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dragfluid Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 3:03pm
OK, thank you.
Series III D-17
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 4:12pm
could you replace BOTH with WD45 swing units ?? ......price if right, if they will fit..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 5:12pm
Series 3 has band/disc brakes. WD-45 has drum brakes. The pinion gear/brake drum shaft iS completely different.
