Running D12 and D14 for sale - Maryland
VTtransam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VTtransam Quote  Post ReplyReply Direct Link To This Post Topic: Running D12 and D14 for sale - Maryland
    Posted: 10 Dec 2024 at 3:00pm
Good afternoon all,
I have a D12 and a D14 for sale, both gas engines - located near Hancock, MD.  Both used for light duty mowing work over the past 30 years or so. Both tractors run, drive, stop and operate well for their age.  Stored in the barn.  I'll note the flaws below.  Not interested in parting out.
ph: seven one seven - 500 - sixty seven fifty three
$2,900 - 1965 D12 - Serial Number 9317.  Has hi/lo range, rear hydraulics, hours unknown.  Engine serial number is 5891.  Engine starts right up and runs smoothly, even in winter, tires good, hydraulics and PTO work (little leak from one rear cylinder), brakes work well, temp and oil pressure gauges work.  The bad: it wants to pop out of gear in reverse and 4th.  1, 2, and 3 are fine.  There is an dent in the gas tank with an old bondo repair job. Video of the tractor from this fall: https://www.youtube.com/watch?v=nBJ5y8lu6Qg
$3,200 -  1960 D14 - Serial Number 23491.  Has homemade 3 pt hitch adaptor, tires fair - will need replaced soon, removeable homemade weight rack on front, oil pressure and temp gauges work, brakes work well.  Exhaust smokes a tiny bit until it warms up, but overall it runs very good.  No transmission issues.  Has a couple leaks, mainly line to oil filter housing.  Video of the tractor from this fall: https://www.youtube.com/watch?v=0Ab8AFt0j3A
Edited by VTtransam - 10 Dec 2024 at 3:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote VTtransam Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 3:01pm
D14:
