Another tire blow out………… |
| Author | ||
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8404 |
Topic: Another tire blow out…………Posted: 10 Dec 2024 at 5:07am |
on our tow dolly. This is the 3rd blow out in less than 7,000 miles, 2nd time the blow-out as totally torn off the plastic fender and lights. ST205/75R14, load range D is the one that blew yesterday. Always kept at proper psi, no dry rot or cracks. Have never had anything heavier than a 2004 Ford Taurus, yesterday was hauling a Honda CRV. What brand of ST tires have others here have decent luck with? TIA.
| Sponsored Links | ||
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1606 |
Posted: 10 Dec 2024 at 7:31am |
What is your air pressure in the tires?
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3611 |
Posted: 10 Dec 2024 at 8:32am |
when I was pulling a camper I had too many ply separations with ST tires. Switched to LT tires and nary a problem after that. They were LR E and I ran them at 80psi which was what was max for the E.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4284 |
Posted: 10 Dec 2024 at 8:37am |
How fast are you driving? A lot of cheaper trailer tires aren't speed rated over about 55.
Lars(wi)
Thanks(1)
Posted: 10 Dec 2024 at 12:40pm |
Sidewall stamped for 65 psi, that’s right where they are at. |
Lars(wi)
Posted: 10 Dec 2024 at 12:43pm |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6621 |
Posted: 10 Dec 2024 at 2:13pm |
Check the manufacture date on the tires. Someone may be selling you old tires that have been stored in a warehouse for too long.
NEVER green
Posted: 10 Dec 2024 at 3:01pm |
I dont like running full pressure, especially on a hot day. Do they make an E tire in that size?
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
Lars(wi)
Posted: 10 Dec 2024 at 3:59pm |
Definitely was not a hot day, temp was mid-50’s.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35701 |
Posted: 10 Dec 2024 at 4:02pm |
Sad to say and sounds wasteful but at Six to Seven years REGARDLESS of Tread Level, the tires on my trailers GO AWAY. Learned that from a Tire guy that was looking at nearly New Looking Trailer Tires were Date Coded eight years, NO WARRANTY to start, one threw a tread where the match to that on other side blew apart.
Ed (Ont)
Posted: 10 Dec 2024 at 8:09pm |
Yes you are absolutely correct. Tires years ago lasted for many years. Now you have to throw away after a few years. And we call that green!!!!! Lol.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42272 |
Posted: 10 Dec 2024 at 9:06pm |
On my tri-axle low boy for hauling dozer and backhoe I wet to LT tires on 16" rims as same size as pickup - no problems with them . Hauled my old D6 a few times but being over width and overweight stayed close to home .
Son bought 4 new ST for his tandem trailer - of the 4 / has replaced 3 in year of using it |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90871 |
Posted: 10 Dec 2024 at 9:14pm |
I think i might be running 45 psi, not 65 psi in the tires.. BLOW OUTS for no reason are due to excess pressure. ... the "D" tire at 65 psi is rated for over 2000# each.. I doubt the front end of that car weighs 2500 #...... 45- 50 psi would be adequate..
Edited by steve(ill) - 10 Dec 2024 at 9:19pm |
DMiller
Posted: 11 Dec 2024 at 2:38am |
Caution with that steve as the tires under load flex far too heavily, causes them to build heat at low air pressure actually degrading the rubber compounds.
steve(ill)
Thanks(1)
Posted: 11 Dec 2024 at 8:02am |
I would agree Dave, if you drop the pressure to 25 psi..... A "D" rated tire set at 45 psi would have a fairly rigid side wall... Dont think it would be a problem... I believe the 65 psi is the problem WITH the Blow outs.
Edited by steve(ill) - 11 Dec 2024 at 8:03am |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 11 Dec 2024 at 8:21am |
i just put all new 16inch 14ply tires on my gooseneck trailer a few weeks ago only have fifty miles on them so far
DaveKamp
Posted: 11 Dec 2024 at 10:26pm |
The reason why tires blow without having an overload, overpressure, or serious bruse or cut, is contamination. Remove the remaining tire fragments, and send them to a lab for analysis, you'll find that there's some contamination inside the tire that caused the failure. Contamination not only results in weakening of the tire, it causes rubber inside the tire to flake off into a dust which is rather flammable. Frequently the contaminant is either an inappropriate tire mounting lubricant (i.e. motor oil or grease, rather than the water/soap based for-purpose swab lube), or some flammable substance used to ignition-inflate the tire. This is a deadly practice, and should NEVER be done. Running at reduced pressure isn't a particularly good thing, unless the tire is totally unladen. Tires that run pressure too low will generate significant amounts of heat from the added contact patch's chord of flexure. Eventually, this heat increases tire pressure internally, but not by much in comparison to the heat that occurs between the layers of rubber and impregnated belting. Once inter-belt friction has worked up the temperature, belts delaminate, the rubber between becomes detached in layers, and more friction occurs, more heat develops, and eventually the tire blows and shreds. Cheap chinese rubber (and the US equivalent 'artificial' rubbers) are lousy in comparison to what was available before 1980. Any one of these circumstances will cause a confounding failure trend.
