7030 tach
MrSnerdly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSnerdly Quote  Post ReplyReply Direct Link To This Post Topic: 7030 tach
    Posted: 09 Dec 2024 at 2:58pm
I got the tractor about 11 months go and the tach didn't work.  I didn't use it much but started using it for field work a couple months ago and the tach started working.  I had to replace the solenoid a couple weeks ago and it doesn't work again.  I am convinced disconnecting the ground cables to install the solenoid had something to do with it.  Will it start working again?   I don't think these are available, either from Agco or any aftermarket source.  I have even checked salvage yards with no luck.  There are electronic tachs available but they are all very high RPM and I doubt they would be as accurate as one designed for the RPM range of the tractor.
